Chris NottBadger5
Results 1 to 10 of 10
Thread: Porsche brakes
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Porsche brakes
    Anyone on here have them or know about them?
    Which calipers work which dont?
    I think both boxter and boxter s work.
    Where do you get the carriers from?
    What discs do you need to get?
    Cheers.
    A4 1.8T Quattro
    Aug 2004
    Hertfordshire UK
    162
    i always thought the boxter calipers used the 312mm tt discs.
    Formally a4 2.5 tdi (b5)
    Now Seat Ibiza tdi 130
    jcb
    Sep 2005
    uk
    4,077
    they all work, 993, 996, Boxter, Cayenne (post 996 they overlap between the models anyway e.g Cayenne and GT3 are the same 6 pots)
    you will need to match discs to calipers through, as the offset can be a bugger, range available that work from A8, RS4 (B7), RS6, through to aftermarket ones from Movit (discs on bells) carriers available from various places like eBay or you can have some made up by an engineer (very simple and you can get the exact dimensions from the spec of the ones for sale on eBay ) and really tailor your choice of discs. By doing this you can avoid using expensive discs (Porsche, Movit, Brembo etc). might cost you more for the carriers but you will save in the long run. there is a tech article for RS2 version calipers on Audi world here
    http://www.audiworld.com/tech/
    Corey's Avatar
    Seeing the world differently.
    Dec 2003
    Anywhere there are Audi's
    77
    Just for the record Cayenne and Gt3 6 pots are not the same, the Cayenne is a lug mount caliper and is a totally different caliper to the GT3 6 pot.
    The Boxster caliper (not the S variant) as stock fits over a 25mm thick disc, we use it (after it has been modified) on discs upto 28mm thick and it can be used on a disc 320 diameter, if you want to go bigger then we need to look at the 996 caliper, this can fit a disc upto 340x30. We also use this caliper on the 993tt cross drilled disc (with custom bell) 322x32mm (again after we have modified it).
    6 pots are really an over kill for your chassis, knowing the wheel size and offset also helps so we can determine the best setup for your car.
    Corey
    quattronics
    01636 822288
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Yeah i saw that a guy on (Jason) here had Porsche Boxter S calipers on his A4.
    I think you can use the S4 discs with them or the a pair of A8 discs. Not 100% tho.
    I would quite like to still be able to use my 17" alloys if I get the brakes.
    Not definately gonna get them as I have the 312mm upgrade but just considering it.
    A4 1.8T Quattro
    Corey's Avatar
    Dec 2003
    77
    All our conversions are based around genuine discs (either Porsche or Audi).
    and a range of Porsche monoblock caliper's
    17" wheel, depending on it's offset you could use the 323x30 disc from the '99 S8 with a 996/Boxster S caliper, you would need a custom brake bracket, which is what my company does
    Corey
    quattronics
    01636 822288
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    Cool could you pm me the price of the bracket please.
    Just want to see how much this will all cost.
    Also send me the prices of the other bits and bobs if you want so then i can see if your cheaper than elsewhere.
    Thanks,
    Paul.
    A4 1.8T Quattro
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    Corey - can you do a Porsche caliper to work with a stock front S4 disk (on a '98 S4)? Stock 17" S4 alloys.
    What would you advise. Looking for a budget upgrade or something I can do in stages at least.
    PM me if you can about .
    I did try calling you a few weeks back - however mobile only number and it wasn't on.
    johnyj's Avatar
    Jun 2004
    253
    porsche caliper sounds nice is the price of pads alot though ?
    im also looking into a bigger brake conversion.
    i have 18" alloys can u give a price for a4 b5 1.8ts
    caliper and discs to fit
    Corey's Avatar
    Dec 2003
    77
    Genuine Porsche pads £50 from GSF (Textar are the OE manufacturer for Porsche)
    Corey
    quattronics
    01636 822288
