Volks AutosJMB Retrofits
Results 1 to 32 of 32
    Sep 2006
    21
    A4 Key Question?
    I have a 1998 A4 1.8T Sport, I have an original Audi key with the car which contains just a small light to illuminate the key lock.
    My question is, should my car have a remote key which unlocks the doors etc? or would the key I have be how it was supplied?
    Damian
    jcb
    Sep 2005
    uk
    4,077
    should have a remote key, i have the same car, comes with two "flick" remote keys and one standard key with code label on it.
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Damian. Is the car English spec or is it an import
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Sep 2006
    21
    English spec car, ex company one owner but I just have a key with a light in it, no remote flick key.
    Gutted as I've read about the hassle getting a flick key.
    I opened my key and it has a transponder inside it, could i buy a flick key from e-bay and get it programed to the car then just swap the transponder for the immobiliser? what key do I need?
    Damian
    jcb
    Sep 2005
    uk
    4,077
    yep blank key, you should be able to swap your transponder, or get some smart arse to program it for you
    Sep 2006
    21
    OK swapping the transponder seems easy enough, how do I program the key to lock and unlock? Also can I buy any type of key or do I need one on the correct frequency? If so how do I know what frequency I need?
    Damian
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    Remote flip keys were an option on the 98 A4's.
    You can check the option codes (found in the front of the service book or on the sticker in the spare wheel well) here to see if it was added to yours:
    http://igorweb.org/equidec/
    Sep 2006
    21
    Checked my option codes and theres nothing there about a remote key so does that mean it's not possible on my car?
    Oct 2005
    Essex, UK
    1,222
    I have a 97 A4 1.8 T Sport, doesn't come with the remote!
    If all else fails you can get a 3rd party kit from Votex, which is very good
    VW Passat 2.0 TDI Sport
    2005 - 55 reg.
    A4 Avant 1.8T Sport - Sold March 09
    1997 - R reg.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Quote Originally Posted by Damian s
    Damian
    I've got an Aug 97 Audi Rangelist (so 98 model ) with prices/specs etc and the 1.8T and 1.8T Sport didn't come with remote central locking, only the SE models had this feature.
    It was an option at 277.30 when your car was new!
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    smitch's Avatar
    Sep 2006
    1,585
    My 96 1.8T sport has remote locking and my mates which is the same year doesn't. There's a little black bubble on the door pillar either side of the car on mine between the back and front doors which must be a reciever. The key's about 4 inches long as well!!!
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    I found this site that sells keys http://www.hickleyvaltone.com/diagno....php?manu=audi
    thought it might be handy for someone
    Jan 2006
    UK
    19
    My '97 A4's got the conventional type key with light. I just bought 2x keys from Audi for about 120 inc., then had to have them coded for another 32.50.
    My car's got remote c/l but from the dealer fit Conlog alarm, not the key.
    Dec 2004
    Lancs, uk
    263
    Smile
    Hi, the easy way to check if your 98 A4 can use the remote flick key (which it should) is to check the part number on your central locking pump, which is located in the boot, on the drivers side, under the little side tray just into the rear wing (it is inside a foam shell).
    If the suffix on your pump is greater than 'A' (which did not have radio reciever) you will be able to use remote flick keys.
    As your car is on a 98, i am pretty sure that it requires a 2 button remote, and not the three button.
    Then you need to either take all your keys to Audi and have the transponders swapped, or as i did, canibalise my second main key and swap the transponder capsule from your old style key to your new flip key. (you can also use the blade if you dont want the expense of getting another cut, but it requires reshaping with a small file to match a flip key blade).
    Then sync your remote to your car and away you go.
    I did this on my 97 A4 TDI SE, which had the same style key as yours. I had to replace my central locking pump with a radio version, any suffix will do, i used an A3 'G' suffix pump on mine (if you change to a pump with another suffix you will need to use VAG-COM to change the soft coding, or the alarm etc wont work).
    It is probably easier to buy a 'Remote locking' addon though, + the range on the audi remotes is terrible.
    Feb 2005
    Isle Of Lewis, NW Scotland, UK
    197
    My A4 is a 1997 R reg TDi SE spec, and has remote locking. I have all 3 original keys, 2 of which are remote, and the third is the workshop key. None of the keys are flip keys though.
    I had the Votex remote locking interface fitted to my previous A4, a 1996 N reg 1.8T, and it was pretty good, and had better range that the standard Audi remotes on my TDi.
    My Fleet:
    B7 Audi A4 3.0 TDi 233 S-line Quattro
    B5 Audi A4 1.9 TDi 110 Quattro
    B5 Audi A4 1.9 TDi 110 SE
    B3 Audi 80 2.0 8v Sport
    macca's Avatar
    Sep 2006
    Sussex.
    525
    i have a 1.8t sport 1998 and the code doesn't list the remote keys, this was fitted at the dealer as an extra at purchase of car, it has it listed on the original sales reciept, i have a remote key, a standard key and a emergency key.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    This may be of interest to those without the remote keys fitted to there cars.
    Comfort radio remote maintenance with turn signal control Now with 2 high-quality folding key Suitably on all: AUDI A3/A4/A6/A8 We offer to you here a comfortable radio remote maintenance set in original equipment manufacturer quality. The radio remote maintenance set is delivered according to standard with a pair folding key with sample blanks. Opening and closing the original central bolting device. Turn signals are headed for with opening and reasoning. Range also over 70 meters. Copy surely with 4.3 billion possible code. Vehicle search function. This radio remote maintenance sets new yardsticks in things quality.
    Ebay link
    Dec 2004
    Lancs, uk
    263
    Angry
    This item does look good, i might try one, however i dont think that it operates the alarm.
    There is also a pre 97 votex system on the German ebay site.
    Does anyone have a pinout diag for the central locking pump (pump's an 8LO-'G'), i have been trying to increase the range on my existing remote, and after prising off the 'C' pillar trim I discovered that there was no ariel behind it. My remote only operates within 3-4 feet of drivers side.
    As my 97 A4 TDI SE did not originally have remote locking ('A' suffix pump), is there an antenna in the pump harness?
    The setup is the same as 98- cars, nothing under rear seat etc.
    filipharvey's Avatar
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Anyone know where you can get an AH profile blade to fit one of the flip style keys?
    Audi A6 1.8T Avant
    Alfa 156 3.0 V6 Veloce
    Dec 2004
    Lancs, uk
    263
    Brass - nickel plated with new mounting pin, 2.99 + free postage.
    Ebay no: 220035144643
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    He only does HAA profile, I'm after AH
    Audi A6 1.8T Avant
    Dec 2004
    Lancs, uk
    263
    Ahh, my mistake, the AH is the pointed VW style blade?
    Sep 2006
    Sorry to bring up an old topic but I bought an 1996 audi tdi (basic spec not se) with just one key (the workshop key (no light)). Having been to audi dealer today to enquire about getting spare key quoted 50 quid for key 50 quid to program key / car + VAT. When i enquired about possibility of central locking he checked my car registration and told me it didnt have remote central locking which i suspected being pre 1998. However checking my codes using the handy link above i find:
    8QL = key for locking system with remote control
    So who do i beileve the decoder or audi? I think the decoder may be right as it was originally bought as a fleet car so the option of r/c/l could more than likely have been added (also most dealer service desks are wrong from my experience). If that is the case could i get a flick key to work with it or not?
    Dec 2004
    Lancs, uk
    263
    For a '96' A4 check under the rear seat base for the infra-red control box.
    If you have one you should be able to use the old style IR remote key.
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Quote Originally Posted by inigoj
    Thats the one. A few people selling flip keys on eBay have pictures showing those blades, but say they are demo only and cannot be cut! Any ideas?
    Audi A6 1.8T Avant
    Dec 2004
    Lancs, uk
    263
    This is the only AH style flip-key blade i can find. It works out around 11 delivered.
    http://cgi.ebay.com/ebaymotors/ws/eB...category=40016
    Ebay No: 290010519462
  28. #27
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Thank you!
    You're a star!!!
    Audi A6 1.8T Avant
  29. #28
    Sep 2006
    Cheers for the quick reply
    Is it a small box in the centre of the seat / floorplan?
  30. #29
    Dec 2004
    Lancs, uk
    263
    Yes, a small box near the centre, should have a small diameter co-ax aeriel coming out of it.
    May or may not look like this:
    http://www.audiworld.com/tech/pix/remotetop.jpg
  31. #30
    Sep 2006
    Ingoj your a legend. Thats exaclty what i have. I just need to sort out a replacment fob and reprogram and i can be as lazy as i like in opening doors!
  32. #31
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Right! Got one sorted! As you say was about £11. Also got a new flip key from the states, that was £15! Bargain! There is also a chap selling 3 or 4 (cant remember!) flip remotes, bidding is at about £20 ATM, might be worth someone buying to sell here!
    Audi A6 1.8T Avant
  33. #32
    Jun 2007
    I have bought a few keys from the States and found they use differant frequencies, so unless you decide to replace the receiver it won't work.
    Although my experiences are on newer cars A4 2002, Touareg 2005, Golf 2003 and Golf 2006
