Sky InsuranceAH Fabrications
    Sep 2006
    west lothian
    1.9 tdi (1997) warm start problem
    i've a problem with my car starting it starts no problem when cold but once it has been running it will turn over and fire up then die the longer it has been running (warmer the car is) the longer i have to leave it for it to restart. i changed the MAP sensor and the glow plugs i also took the plunger out of the fuel cut of solenoid but still the same any ideas would be appreciated as i phoned my local garage and they didn't really want to have a look at it and the VW garage don't do Audi anymore nearest VW\Audi dealer garage that will look at it is 25 miles away.
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Mark.
    My dad had a similiar problem on this '00 A4 PD TDI. Would start from cold but once the engine was warm if you tried to start it you had to crank it for ages to fire it up. Turned out the EGR (exhaust gas recirculation valve) was knackered.
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Sep 2006
    west lothian
    when its warm it briefly starts then dies if i keep turning the key it does this 3-4 times then it just turns over without firing up i then have to leave it for some time then it starts ok.
