Volks AutosEM Tuning
    Sep 2006
    ABS and ESP warning
    Hello, I am new to the site. My ABS and ESP warning lights come on if i sit at around or above 85mph for 2-3 mins. Once on it stays on till i turn ignition off. I changed the rear disc recently and the ABS rings seemed fine. Any ideas?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    Did you clean the sensor?? it deffo sounds like a dodgy reading from somwhere, and the ESP and ABS get their signals from the same sensor AFAIK
    Feb 2004
    Halifax, West Yorkshire
    79
    I have had this on my 2003 A4 1.9Tdi Sport.
    Don't panic!
    In my case, I had damaged the microswitch that is under the brake pedal. This was causing the car to get upset because the car was braking but the lights and engine didn't think it should be. After a while the ESP light came on too at about 80mph. Getting VAGCOM or any other ECU diagnostics will detect this.
    I also had the same issue on my 1998 A4 1.8T Sport - this time it had the same issues but was the actual sensor. I sorted mine by cleaning the sensor and making sure that there is no dirt around it. Reseating it seemed to do the trick. If not, I found the sensor for about £100 from GSF in Reading.
    [.:: brixo ::.]
    2008 Audi A4 2.0 TDi 170 S Line SE Avant, Lava Grey, RNS-e, happy to be back to an Audi!
    2007 Porsche Cayman, 2.7 stock lump. Bought the wrong engine. Amazing chassis gone...
    Previous Audis - A3 1.8 SE, B5 A4 1.8T Sport, B6 A4 1.9TDi Sport, B5 S4 Avant, B7 A4 2.0TDI S Line, B6 S4 Avant...
    Nov 2004
    Kent, UK
    138
    If you need an abs sensor let me know. I have all four from my 2000 S4 which I am breaking.
    Audi ones retail at 119 new
    John
    B5 S4 avant - for sale!
    Allroad 2.7T
    simonwjones's Avatar
    Aug 2005
    staffs uk
    344
    Brixo is right, its either the brake light switch or it could even be a bad bulb connection
    had it on mine about two weeks ago, only occurred after braking at a roundabout
    Simon
