Chris NottSky Insurance
Results 1 to 8 of 8
    Mar 2004
    Please Help (Possible electrical fault) A4 :(
    Hey guys
    I have an Audi 1.9tdi (R Reg 1998).
    Basically I switch the engine on (everything starts up fine) then when I use the left or right indicators they dont work, and when I do the window wipers they do not work either. (They are both linked somehow)
    I then switch the engine back on then they start working again, and then stop again. Basically they start and stop throughout the engine being on.
    I have checked all the fuses in the fuse panel located on the inside driver panel.
    It seems to me I havent checked all the other fuses or there is some kind of wire loose?
    Any help or advice would be much appreciated.
    Indy
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,566
    i would probably rule out fuses as sometimes they work and sometimes they dont indicate a power supply is occassionally there.
    I would look at more of a loose connection from the stalks, or an earthing problem possibly linked to the ignition switch?
    check all the wiring looms from the steering column.
    Just my 2p.
    Dan
    2002 2.5 V6 Quattro
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    Ignition switch mate, common fault sadly
    Mar 2004
    Angry
    Quote Originally Posted by mawhitey
    roughly how much am i talking about mate? and would it be easy to fit my self?
    im sick of my audi, had loads of problems
    Apr 2004
    12,500
    IIRC its around £20 thereis a how to somewhere.... might be on Audiworld.com
    Jun 2003
    World of my own
    9,813
    Yes it's really easy, 30 minute job. Go to:
    http://www.audiworld.com/tech/elec.html
    then page down twice and select Ignition switch replacement.
    I've got a PDF of the article but you can't link straight to it for some reason.
    The part no. you need is 4A0-905-849-B and my local dealer had one on the shelf as it's a common problem.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Just did mine 3 weeks ago easy job just dont try and switch the ignition on when the air bag is unplaugged as i did as i have the light on the dash and need it reset
    Place to buy
    http://cgi.ebay.com/ebaymotors/New-A...QQcmdZViewItem
    Works out to be £10ish...takes 5 days to get here
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    I'd say ignition switch as well (same thing happened to me). It is quite straight forward, but make sure you get the correct switch as there are different ones for the A4 (as I found out).
    Also if you are driving the car around before you get it fixed make sure that the starter motor doesn't stay engaged after you start the car. This happened to me and I ended up having to change the starter motor as well which costs over 100 and is a pig of a job.
