Hey guys
I have an Audi 1.9tdi (R Reg 1998).
Basically I switch the engine on (everything starts up fine) then when I use the left or right indicators they dont work, and when I do the window wipers they do not work either. (They are both linked somehow)
I then switch the engine back on then they start working again, and then stop again. Basically they start and stop throughout the engine being on.
I have checked all the fuses in the fuse panel located on the inside driver panel.
It seems to me I havent checked all the other fuses or there is some kind of wire loose?
Any help or advice would be much appreciated.
Indy
Indy
