Volks AutosSky Insurance
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,566
    Vag list of faults....
    Replaced ecu, had some faults, cleared them and ran the car.
    Now i have these faults but im concerned about the first fault!
    I dont have cruise control so maybe activated in the Car ecu came from?
    My MAF is only 3 months old!!!! Spoke to my mate at VW where i got it from and he is ordering another one for a straight exchange as is under a 24 month warrenty.
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 8D0 907 551 C
    Component: 2.7l V6/5VT G 0002
    Coding: 05611
    Shop #: WSC 00581
    5 Faults Found:
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35-10 - - - Intermittent
    17977 - Cruise Control Switch (E45): Implausible Signal
    P1569 - 35-10 - - - Intermittent
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D10
    Coding: 0273004284
    Shop #: BB 24334
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller:
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 919 930 KX
    Component: B5-KOMBIINSTR. VDO D17
    Coding: 04462
    Shop #: WSC 00216
    IMMO-IDENTNR: AUZ7Z0A1791491
    Address 25 -------------------------------------------------------
    Controller: Bitte Adress
    Component: e 17 eingeben
    No Faults Found
    or DTCs not supported by controller
    or a communication error ocurred
    Address 35 -------------------------------------------------------
    Controller: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D08
    Coding: 16204
    Shop #: WSC 06313
    4 Faults Found:
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    00956 - Key 2
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06313
    1 Fault Found:
    01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
    35-00 - -
    Address 55 -------------------------------------------------------
    Controller: 4B0 907 357
    Component: LEUCHTWEITEREGLER D001
    Coding: 00004
    Shop #: WSC 06313
    Address 56 -------------------------------------------------------
    Controller: 4B0 035 186
    Component: Radio 0001
    End -------------------------------------------------------
    cheers,
    dan
    2002 2.5 V6 Quattro
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    i know the
    Is usually a flat battery, seeing as the car it came from was probably decommisioned, i cant see a prob there, next step is to switch off the cruise and go from there i guess
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    this may sound stupid, but try clearing all of them and trying again ?
    a lot of the 1st ones just seem like battery disconects
    Power On
    Feb 2006
    Scotland
    26
    Quote Originally Posted by S4_dan
    Coding: 05611
    Shop #: WSC 00581
    5 Faults Found:
    cheers,
    dan
    This one means you have a boost leak somewhere, I had it too on mine & had to replace some hoses to get rid of it. What a difference when it was cleared though.
    Daz
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    FYI I have posted a link to the wiki site with a list of all vag com fault codes, its a sticky post in the vag com section
    S4_dan's Avatar
    Jan 2006
    1,566
    Cheers OLLY K, had a look so will check the pipes etc.
    I did check some parts whilst my car was redundant. i checked by removing and cleaning the tbb and visually checked the f-hose whilst it was still attached and all looks ok.
    (Reason why i left the f-hose attached was it has some clips on that arent done by screw and i didnt have any means of getting them back on if i removed them, nor did i have any jubilee clips that would of replaced them)
    Which other hoses are worth looking at?
    Also, the N75! i know it has been discussed to death in several posts...but i still cant work out if fitting the N75J valve to my 'standard' S4 if it would make any difference?
    Some posts ive read say it wont make any difference, some say it will? can anyone clarify once and for all please?
    I have never checked or even located my N75, so maybe that is needing a clean or a replacement.
    cheers,
    Dan
    2002 2.5 V6 Quattro
