- Joined
- Jan 5, 2006
- Messages
- 2,847
- Reaction score
- 188
- Points
- 63
- Location
- Somewhere in the Howardian Hills!
Replaced ecu, had some faults, cleared them and ran the car.
Now i have these faults but im concerned about the first fault!
I dont have cruise control so maybe activated in the Car ecu came from?
My MAF is only 3 months old!!!! Spoke to my mate at VW where i got it from and he is ordering another one for a straight exchange as is under a 24 month warrenty.
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 907 551 C
Component: 2.7l V6/5VT G 0002
Coding: 05611
Shop #: WSC 00581
5 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 930 KX
Component: B5-KOMBIINSTR. VDO D17
Coding: 04462
Shop #: WSC 00216
IMMO-IDENTNR: AUZ7Z0A1791491
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D08
Coding: 16204
Shop #: WSC 06313
4 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06313
1 Fault Found:
01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
35-00 - -
Address 55 -------------------------------------------------------
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D001
Coding: 00004
Shop #: WSC 06313
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio 0001
End -------------------------------------------------------
cheers,
dan
Coding: 05611
Shop #: WSC 00581
5 Faults Found:
Coding: 0273004284
Shop #: BB 24334
Controller:
Coding: 04462
Shop #: WSC 00216
No Faults Found
Coding: 16204
Shop #: WSC 06313
4 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06313
1 Fault Found:
35-00 - -
Coding: 00004
Shop #: WSC 06313
cheers,
dan
