AH FabricationsBadger5
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    welding on the car
    i was looking under the car this morning (i dropped something) and noticed that on of the exhuast hangers has broken away from the exhaust.
    its not the one on the back box but the next one in, it has made a hole just the weld has broken
    i was going to weld it back in place as i know how to weld but the question is do i have to disconnect the battery or anything before i start, and if i do what problems wil i have when i reconnect it (settings/alarm/ etc)
    alan
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    you disconnect the battery.......not sure of the impiclations but you will soon find out or you can take the exhaust off which is probably a better idea how you intend to weld it with ..Mig..Ark...Gas Bottles...found the best trick for welding exhaust was to use old coat hangers with Gas bottle
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    jcb
    Sep 2005
    uk
    4,077
    alternator also, think if it the exhaust you would be easier taking it off though
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,596
    safest bet removing the zorst then you wont need to disconnect the battery and search for your radio code, reset the clock etc. plus any welding is best away from the fuel tank etc plus a chance of grease and gunge catching fire from sparks....heat etc.
    2002 2.5 V6 Quattro
