Chris NottVolks Autos
Results 1 to 10 of 10
    Jul 2006
    324
    diy induction kit
    have recently fitted an induction kit to my 1.8t. not many on the market,some around Ł80 so made my own. remove airbox top,disconnect plugs etc( be gentle,airflow sensor very brittle). remove lower airbox. remove airflow sensor and heat sink from airbox lid(be careful airflow sensor very brittle). fit air filter to airflow sensor. i used kn filter from demon tweeks,part no. re-0930 or rm-3001 should also fit (76mm diameter inlet pipe). fit unit to inlet pipe. reconnect plugs position heat sink nearest wing, refit cold air feed pipe. only problem is the heat from the turbo directly below so i made a heatshield- 1/8" ally plate,10" across,13" high with a 1" 90deg lip at base to mount on inner wing frame/x-member. drill and mount it with filter removed then remove, bend and shape over the turbo. drill and mount the pipe clamps to the shield to prevent chefing the pipe. gives a nice subtle sound,noticeably better pull in lower gears. if anyone wants pics pm me and i will email them to you.
    Cali's Avatar
    Jul 2004
    North West
    134
    Pics Please
    Hi goon
    Love to see some pics - sounds interesting and promising.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    stick some pics up on the boards mate you need to use [img] tags
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    use photobucket or one of the other free sites.
    just a little a6
    A11 EAF's Avatar
    Aug 2006
    Scotland
    51
    All those days watching Blue Peter finally pay off!
    Drive it like u stole it. A3 3.2 DSG S-line.
    Jul 2006
    324
    just a quick add on to say the heatshield actually works. measured temperatures in the engine bay were - 35 deg at air filter, 59 deg other side of plate.
    jcb
    Sep 2005
    uk
    4,070
    bet it doesn't sheild heat when you are stnding in traffic having been hooning around town... I know as mine was the same. I now have a different set up.
    Is that an oiled filter? not recommended due to the MAF
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    I did a little diy myself at work. http://www.putfile.com/pic.php?img=3299565
    Basically a K&N 57i kit inside the original airbox with the original cold air feed and heat shield.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    looks good that but wouldnt work for a turbo car
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Planning on getting it supercharged to be different
