Was wondering which companies people have extended warranties with for there Audi's ?
Am just about to purchase one for my T Sport (1996) and am interested to hear any experiences etc good or bad.
Main ones I have seen have been via the Autotrader website - looked at RAC too but the cover i.e excesses and max claim cost seem pretty low.
Best one I have seen is from Warranty Direct - would welcome and feedback on the comprehensiveness of the parts covered /ubbthreads/images/graemlins/wink.gif
Warranty Direct £253 - pa
Standard Cover
Comprehensive Protection
Claims limit = £5,000 per claim
Excess = £0
Parts and Labour
Recovery
Car Hire
Overnight Hotel Accommodation
24 hour freephone helpline
Central billing
With Standard Cover all of the following parts are covered and we will pay the parts and labour costs if you have to have something replaced.Parts not specifically mentioned are not covered.
Engine
Cylinder head, internal bushings, oil pump, crankshaft and bearings, tappet gear, valves and guides, pistons and rings, cylinder bores/liners, con rods, distributor drive, starter ring gear, flywheel, auto drive plate, camshaft drive belts, camshaft and cam followers, cylinder head gasket, turbo/intercooler units, rocker assembly; push rods; timing gears; timing belts and chains.
Clutch
Master and slave cylinder, clutch cable and pedal assembly.
Transmission
Manual Transmission: gears, synchromesh hubs and rings, selectors, shafts, bearings, drive chains plus gear lever and bushes. Automatic Transmission: torque converters, brake bands, valve block, governor (manual and electric) oil pump and seals, drive chains, gears, input shaft oil seal, clutches, servos and modulator valve, bearing plusgear lever and bushes. Overdrive: Gears, shafts and bearings.
Front Wheel Drive Unit
Crown wheel and pinion, bushes and bearings , plus external drive shafts, universal joints and couplings, C.V. joints and differential unit.
Rear Axle
Crown wheel and pinion, shafts, bearings, hubs and hub bearings, C.V. joints and differential unit.
Four Wheel Drive System
Shafts and bearings, plus propshaft, couplings, C.V. joints, front differential: interaxle differential and lock; rear differential and lock.
Propshaft
Propshaft, universal joints and centre bearings.
Suspension
Upper and lower wishbones, control arms, stabilising bars with associated ball joints, swivel pins and bushes, displacer units, wheel bearings, tailgate suspension struts.
Braking System
Master cylinder; brake servo unit, calipers, wheel cylinders, pressure reducing and proportioning valves, ABS pump and control unit.
Cooling System
Radiator, thermostat, water pump, heater matrix, viscous fan, thermostat housing.
Steering
Rack and pinion, steering box, idler box, column shaft, couplings, power steering unit including pump, pressure pipes and reservoir, tie rods and tie rod ends.
Fuel System
Mechanical and electrical fuel pumps, carburetors, airflow meter, fuel distributor, warm-up regulator, cold start injector, fuel gauge and tank sender unit.
Diesel Injection System
D.I.S. pump and injectors.
Electronic Ignition
All solid state control and triggering units, where fitted as standard by the manufacturer.
Air Conditioning
Air conditioning. compressor pump, condenser, fan control, sensor, magnetic clutch and valves, evaporator and reservoir.
Electrics
Internal failure of the starter motor, alternator, regulator, distributor, windscreen wiper motor, horn, electric window motors and front and rear windscreen washer motors, indicator flasher unit, heating fan motors and cooling fan motor.
Casings
Casings are covered provided they have been damaged as a result of failure of an insured part or by the consequential damage of an insured part failing.
FE /ubbthreads/images/graemlins/smirk.gif
Standard Cover
Excess = £0
Parts and Labour
Recovery
Car Hire
Central billing
Engine
Clutch
Transmission
Rear Axle
Propshaft
Suspension
Braking System
Cooling System
Steering
Fuel System
Electronic Ignition
Air Conditioning
Electrics
Casings
