EM TuningSky Insurance
Results 1 to 7 of 7
    it was cheap as chips!!
    Jul 2006
    Doncaster
    Question 2.8Q tech questions
    Guys
    Had the 98R 2.8Q for a couple of months now
    need the 'oh so knowledgable ones' to help me
    1) idle speed-what should it be and how to adjust? was told that if you dis the battery you need to get the idle ecu reset?
    2) will S3 alloys fit? some nice ones in the classifieds :biggrin:
    3) Just bought some 40mm lowering springs-are they a diy fit, if so, a brief 'please explain' would be nice :smile:
    4) bit smokie on start up -whats the verdict can you change valve stem oil seals using the compressed air method??? without taking off head???
    do you know anyone that does this??? sth yorkshire
    other than that i'm happy with the beast
    1250 full grey leather Hibiscus red with 18" RS8 reps on (getting RS4's so will be for sale cheap soon) 150k good history,drinks a little (valve stem oil seals) but everything works
    Ta
    CC
    Jun 2003
    World of my own
    9,813
    Idle speed is about 700rpm once warm, a little more when cold.
    S3 alloys definately won't fit as they're 100PCD, whereas the A4 is 112. You'd need S4 alloys or above.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    Jul 2006
    Doncaster
    cheers guys
    How do I adjust the idle as its too low and it feels like it wants to stall as i pull away from the lights??? unless i rev it
    CC
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    You need to clean out the throttle body and realign it with VAGCOM this may fix your idle problem issue.
    Jul 2006
    Doncaster
    aarh do they need VAGCOM to set them up? it had a new throttle body before i bought it....mmm
    Whats it gona cost to get set up with software and VAGCOM??
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    Moody copies of it can be found on the net and then just a ebay lead and your good to go.
