k04 and k03 are two different turbos, k04 bigger and more boost
they also come in longitudinal (a4, a6) 1.8t engines and transverse (a3, s3) 1.8t engines. this is the most important difference the turbo housings are different to fit the different engine layouts.
both are bolt on in place of standard turbo k03 as long as you get it from the correct chassis
You can probably use the old compressor housing from the K03 on your car and bolt it onto that one you have there... as long as you know what you're doing
You'd be surprised how easy it actually is though... a simple case of approx. 6 bolts... undo them, remove old housing, replace with new. JD.
Obviously if you can get a K04 for the same/similar money then go that route... but you will need it mapped corectly to fully realise it's potential which again, will obviously mean more cost.
What exactly is the problem with your old turbo? I'm guessing bearings.. ?
Thinking about it, because of the orientation of the A3 turbo, you will have to change the turbine housing too but if it's the bearings that have gone then it's the CHRA that holds them so that is actually the only part you need... just bolt on the correct housings and you're good to go
Theres nothing wrong with mine at the moment! Just that its probably the original one and as this is nearly new and as I said has cost me next to nothing I thought it would bolt staright on.
But its getting more and more complecated, so perhaps Ill just leave it lol..
It's easy enough though... if you're going to remove the turbo anyway then it won't take long
Remove housings (turbine and compressor) from new turbo, approx. 4-6 bolts on each.
Remove old turbo from car
Remove old turbo housings and replace with new, taking care to clock (orient) them correctly so that all inlets/outlets face the same way as the old ones.
The turbo which you have is off an a3 and is of no use to an a4 at all. Both the compressor housing and exhaust housing along with orientation are very different on an A4 turbo
As you can see in the below pic of an a4 exhaust housing it is completely different to the A3 item
Differences continue with the compressor end
So I am sorry to say there is now way you can use anything on the new turbo, unless the internals are the same
As I mentioned above... you can use the turbo you have but the only way is to use your old turbine and compressor housings off the current turbo...
The CHRA (Centre Housing Rotational Assembly, which includes bearings shaft and both wheels), which is essentially 'the turbo', should be the same for all K03 turbos (except the K03s which has different wheel profiles), i.e. same wheel sizes and therefore same housing ID's. The variances between models are in the different housings used with them for different engine/exhaust/inlet orientations. This is clearly illustrated in the pictures that both of you have provided
One thing that could prevent you from using the old housings is the fact that they may become 'scored' in the situation where a turbo is being changed because it's bearings have failed. When that is the case there will be excess play in the shaft which causes either or both wheels to rotate off-centre and collide with the housings, causing undue wear on the inside surface and hence preventing the turbo flowing to it's capacity.
I hope that explains in a little more detail what I was suggesting before...
if it isn't broken I wouldn't tryto fix it. if you are going KO4 you will need a new manifold and a remap anyway, you may as well go GT28 and do it properly
Sorry guys Im only going by the limited knowledge I have.. Im going to start buying bits month by month to build a half decent spec engine as Ive finished with the externals of the car, all bar new wheels.
So my plans are/where
New turbo uprated of some sort!
Bigger injectors
de-cat
FMIC
Re-map
Mabey some head work and cams (unsure of this) as im not sure if I want to get that involved.
Re-map
Now I thought the KO4 was a bolt on upgrade and as its not, I dont want to be faffing around with swapping bits here and there.
So ill sell the K03 above and put it towards a new turbo of sorts!
