Sky InsuranceAH Fabrications
    eastside_valver's Avatar
    Jul 2006
    Aberdeen
    37
    oil pump fixed......turbo broken !
    Well, my oil pressure problem has been cured with a new oil pump , but the low oil pressure seems to have killed the bearings in the turbo.
    Where's the best place for a good used/reconditioned K03 charger ?
    or
    Is this an ideal opportunity for a turbo upgrade ?
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    Quote Originally Posted by eastside_valver
    yes i'd say slot in a k04 don't need any upgraded hardware
    just a little a6
    Jul 2006
    Aberdeen
    37
    where's the best place to source a replacement turbo ?
    what difference would a K04 make over the standard K03 ?
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    They look the same from the outside but the internals are different.
    The K04 is kind of bored out and has more aggressive turbines inside.
    It holds more boost higher up.
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    ZeroK66's Avatar
    Jun 2004
    Devon, UK
    246
    You can get about 240bhp rather than 210 with a remap! Get a K04 - cost you no more.
    Sorry to hear you had the turbo go though. That sucks.
    Facelift Imola S4 | Custom: K04's, Tubular Manifolds, 3" DPs-> 2.75" Catback | FMIC | H&R Coilovers + ARB's | Brembo 8-Pots | SS + DTS | 503HP/475lbs/ft | 1800W RMS
    Sold: Audi A4 (B5) 2.8 Quattro | Ivory Pearl
    Melted: Corrado - IHI 1.8 20vT: 343BHP
    jcb
    Sep 2005
    uk
    4,070
    isn't the manifold flange different?
