Volks AutosEM Tuning
Results 1 to 9 of 9
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Everything comes in three(just not women)
    Neighbour hit my car on Monday so going into garage on Monday to get fixed
    But in that time i think my immobiliser is playing up as the car has not been starting and the lights have been flashing on and off after the glow plug lights go out and only after switching the ignition on and off a few times it has worked.........so is it ignition barrel or immobiliser??
    Next i lose the indicators and the front windscreen wipers when i get back from work today so i am looking for a relay or a fuse ...?
    Steve
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    I would say ignition barrel. Similar thing happened to me when mine went, it affected the wipers and the aircon, just before it broke completley and trashed my starter motor as well. It is probably worth changing this as a precaution as they are only about 20 and not too difficult to change yourself (excellent article in the tech section on audiworld.com).
    Does your key feel stiff in the barrel ?
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Bang on ,i have to make sure when i start it that i turn the key back as it is not re-coiling back and sticking leaving the starter motor on
    Were did you source Barrel and A4 section audiworld i take it?
    cheers
    Steve
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Jun 2003
    World of my own
    9,813
    That article on Audiworld is spot on, saved me a 150 as my garage wanted to fit a new ignition barrel and get it coded for my keys etc etc.
    See this thread
    Burnt out starter motor
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Looking in the tech section but struggling to find barrel removal
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    Jun 2003
    World of my own
    9,813
    Hi Rev, you don't have to remove the barrel. The sprung section of the ignition is the connector at the end, which is secured by 2 small screws (painted red). Can't give you the URL from AW but it's under Electronics then a couple of page downs and it's called "Ignition Switch Replacement"
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Cool thanks Andy......did you buy straight from audi or did you get from vagparts.com
    Urq RR
    S2 Coupe...RS2 +
    A4 AVANT TDI
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Got mine from Audi.
    Jun 2003
    World of my own
    9,813
    I got mine from Audi and they had it in stock 21
