Volks AutosSky Insurance
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    2.8 quattro auto throttle cable?
    my throttle pedal bounces up and down sometimes when i hit a bump, iwas told it could be something banging against the throttle cable as they are very tight
    question is where is it, ive taken of the engine cover but cant see one any where, nor can i feel one when i put my hand up by the pedal top,
    does my car have one or is the throttle opereated by wire/electrical?, or am i talking rubbish
    the car is a 1999 v reg
    alan
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    i think what is being referred is throttle valve cable to the transmission you need to check under the car the route of the cable to the shifter levers on the box.
    fyi engine is likely electronic for that year you wont have throttle body cable it runs of position sensors
    just a little a6
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,344
    I had a 2.8Q with drive-by-wire, and it used to do the same. Don't worry about it. I know it feels like summat's up, but trust me, it's not.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    i didnt think i had a major problem but surely it didnt leave the factory like that so any ideas wha/where to look for the problem
    alan
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,344
    I've had three A4s now, and every one of them has done it. Don't go looking for a problem when there isn't one.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,014
    cheers guys i wont try fixing something that going to be hard to fix, if its not causing a problem, just thought id reasure myself first
    alan
