'98 S4 Foot Well Lights not working :(
GSB1
UK
Website
www.shootpetrol.co.uk
1998 PRE-FACELIFT S4.
Basically neither of the foot well lights work. The rest of the interior lights work when a door is opened.
None of the fuses in the dash are blown, nor are either of the bulbs.
I have tested the +ve (Grey/Red cable) side of the connection (with the door open and other interior lights on as expected) with a meter grounded to the car (eliminating the door switches etc) and there is no voltage. There is continuity on the cables between both lamps where I would expect it, so I don't think any cables are broken.
I replaced relay 382 that my dealer told me was the "Door Entry Lights Control" but this has not changed anything.
I am pretty stuck now. For some reason there is no voltage being supplied to either lamp (my drivers side - RHD) is the master supply with a dual Grey/Red cable that feeds the passenger side.
I just don't like the lights not working when they should.
Can anyone help?
Help/diagrams etc all appreciated.
Regards
Graham
Was relay 382, position 1, relay board behind the front obvious relay board under the stering column panel. Controls red door lamps too.
Do you get a display on the DIS now for an open door?
11
12K
588
imported_tyrant
I
9
