Chris NottSky Insurance
Results 1 to 12 of 12
Thread: Key Fob Range
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Key Fob Range
    Any ideas how to improve the range of the key fob?
    I've changed the batteries in the fob and it didn't improve much at all.
    I've located what I think is the control unit (under rear bench) does it have and external aerial or is it internal, i.e would it help to relocate the unit somewhere higher?
    2001 A4 Avant SE 1.9TDi
    Jul 2005
    UK
    52
    You could try jeremy clarksons trick, keep pressing the key until you out of range, then when you out of range hold the key to your head and press the button.
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Yeah have done that in the past, the range still isn't that great, maybe I've just been spoilt, my previous car had a clifford on it that worked for a huge distance!
    Phantom_A4's Avatar
    Jan 2006
    Southwater, United Kingdom
    562
    Yep they only work at short range....Apparently to increase security if you accidently press the button whilst far away....Won't be anywhere near as good as a reliable clifford..
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Ahhh thanks,
    The short range isn't that much of a problem, but it does have trouble dropping all the windows from the key fob, I push and hold the button but I have to be standing right next to the car for the windows to open, any further away and they don't open, which defeats the object really!
    I may do some experiments with the reciever, unscrew it and levitate it in the car somewhere just to try it out.
    johnyj's Avatar
    Jun 2004
    253
    mines the same with the windows sometimes doesnt even work
    ive found if your walking to the back of the car its better reception.
    Phantom_A4's Avatar
    Jan 2006
    562
    Yea you get a better response if you attack it from the rear! lol!
    necroeire's Avatar
    Feb 2004
    Ireland
    1,003
    Well I can get mine to work form 300m by holding it against my head, normally it works at 50-75m.
    B6 A4 1.9TDi 130Bhp, 18" RS6 Reps, iPod ICELink, S4 Grill, S4 Door Flares
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    50-75M normally! I'm lucky if i get 3m!! Against my head it's still only about 10M
    Missed gear
    Jan 2006
    Kent
    386
    Normally get around 50m from mine. Against head doesnt make much difference - maybe got the wrong sort of head !
    B7 A4 Avant S-line Special Edition v2 2.0 TFSi - AmD stage 1 - 263Bhp 396Nm
    Apr 2004
    Swansea, South Wales
    528
    Open your mouth!!!
    If you hold the key to your head, open your mouth and point at the car.....
    Jul 2006
    Chicago, IL
    13
    I have also noticed that the range on the fob is short and it does work better from the back of the car. My windows do not roll down either.
