Thread: How much Psi
    Apr 2006
    Bicester, Oxfordshire
    55
    How much Psi
    Can the std K03 turbo handle?
    May 2006
    Sunny Isle
    265
    It wouldnt be the turbo id be worried about! It would be the internals of the engine as to much boost and not enough fuel isnt a good combi!!
    As for how much boost the standard turbo can handel, I supose it depends how long u want it to last. Im sure you could run it at 20psi with not many problems ? But Ill let the experts on here give you the correct figures instead of my uneducated ones
    Dave
    Apr 2006
    55
    I dont want massive boost just i believe it runs 6psi std and thought about running 10-12psi
    May 2006
    Sunny Isle
    265
    is there an easy to to wind a little more boost then ??
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    you could go old school and wind up the actuator not recommending that as safe for the engine, far better to get a remap though the car will run more efficiently off boost and safely on boost. and these engine internals are fine to around 22psi repeatedly with correct ignition and fueling timings
    just a little a6
