AH FabricationsJMB Retrofits
Results 1 to 8 of 8
    ScottyBoy's Avatar
    Audi A4 TDI Owner
    Jun 2006
    Milton Keynes
    79
    Front Brake Pad Change Which Ones ...
    hi guys
    pads need doing up front this weekend badly
    been told theres 2 sorts
    had them priced at my local motor factors there Ł11 or Ł22 and i dont know which set they are
    anyone know
    and take it pads to change on the front are quiet straight forward, done plenty on fords etc
    Scott
    Audi A4 1.9 TDi Owner
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    front is straight forward push the piston back type, as for what type that will depend on year and engine size I would have thought.
    Best bet buy all three and then get them to refund you the two you do not use most good shops will do that.
    ScottyBoy's Avatar
    Audi A4 TDI Owner
    Jun 2006
    Milton Keynes
    79
    well from what i can understand its down to brake pad is low warning ,well 1 side grinded last night and then stopped, so i had no warning light , so guessing its the non warn notification etc, pads,
    mine been the 1.9 tdi b5 96 plate
    ScottyBoy's Avatar
    Audi A4 TDI Owner
    Jun 2006
    Milton Keynes
    79
    bought now hopefully the correct ones
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    get some pics when you do em scott. ive got mine to do sometime
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
    ScottyBoy's Avatar
    Audi A4 TDI Owner
    Jun 2006
    Milton Keynes
    79
    no worries the audis are so damm easy to work on compared to fords its unreal , it makes ford look complicated
    although some bloody arse monkey f**ker excuse my french has bodged the caliper carrier so ive had to buy one from a scrappy in dorset after ringing round for ages, the lower bolt to undo the caliper would undo but when you fit it back up it was out by 5mm and wouldnt budge for love nor money, even with a good feckin clout with a hammer ! so iam carless now till tuesday when it arrives !
    other from that its a joy to work on and so easy, the coilovers will be nice to fit too compared to ford too
    Davelad's Avatar
    Apr 2006
    Whitley Bay, Tyne & Wear
    30
    Did you look into getting the EBC Greenstuff pads etc, I need to change mine very soon, not sure which to go for.
    johnyj's Avatar
    Jun 2004
    253
    ive got greenstuff all round find them good at high speed but not at low speeds for some reason
