Badger5JMB Retrofits
    EnzoS4's Avatar
    Sep 2005
    UK
    200
    Electric Windows (Rear)
    On the rear windows, I just push the button once and the window(s) go down on its own. but when closing the window(s) - I have to keep the button selected to close them. I remember reading some where how to reset this so that it works on its own, but can not find it. The fronts work ok.
    any ideas...?
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    When you find out PM please that is something that i have never figured out
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,618
    Me tooo! MIne will go down in auto but not up. I think this is standard setup.
    When the battery is disconnected / reconnceted, all windows only work manually. you have to set them the by pressing and holding the front window button downs until windows fully open, hold for a few secs then lift up to close windows again holding for a few secs.
    Then do the same procedure for rear windows.
    This is the only way i know of resetting the auto window feature fully but the back still wont go up in auto.
    Dan
    2002 2.5 V6 Quattro
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    My fronts are auto up and down, the rears auto down only. The fronts on my escort before Audi would not auto up, It's a safety feature i believe. To stop you and in the rear i would have thought kids trapping themselves.
    EnzoS4's Avatar
    Sep 2005
    UK
    200
    I did original try pressing the switch for a few seconds once down and doing the same for the up, but like you said this only works on the fronts not the rears. I will have to do some digging to see if vag-con can change this setting... unless anyone knows that it can not be changed in vag-con...?
    on another note, are any of you S4 guys going tomorrow to the GTi Internations...?
