JMB RetrofitsChris Nott
Results 1 to 15 of 15
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    throttle pedal bouncing?????
    the throttle pedal in my 1999 2.8 quattro seems to sometimes bounce/shake or vibrate when i hit hit a decnt bump in the road, it only seems to do it when its passenger side that hits a big bump, otherwise its fine
    im new to the a4 but cant see why hitting a bump would cause to throttle to do this......help please
    alan
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    anyone?
    or is it just my car or just me imagining things
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    i think the lack of replies means its a very odd one indeed !
    I would look at the suspension strut for the passenger side and make sure everything is ok, baffled as to why you would feel it on the pedal though, maybe vibration from driveshafts or something
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,002,028
    Follow Administrators On Twitter
    Just a quick question is the car a throttle cable car? Is the peddle lifting up or is it a vibration?
    Administrator
    Oxfordshire
    1,000,002,028
    Ok that was two questions
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    dont know if car has a throttle cable i havent took the covers away round the pedal to see, but could feel one when i reached uo their just a box/wires.
    and the pedal seems to sort of vibrate more than lift up
    Feb 2006
    Bristol, England
    14
    Throttle 'judder'
    I have just experianced something similar as I went over one of those small sharp edged speed bumps. I was driving over it so my foot was on the throttle and I hit it a little faster than I normally would and the throttle pedal juddered in a similar way to the way the brake pedal does when the ABS is activated.
    I've no idea what it is, and I've not noticed it at any other times, so probably not much help to you, but at least you know you're not going mad :o)
    Nic
    Feb 2006
    Bristol, England
    14
    oops
    Forgot to mention, that was on a 98 A4 avant 2.8 if its relevent...
    Phantom_A4's Avatar
    Jan 2006
    Southwater, United Kingdom
    562
    I would say it would be something in the engine bay....Depending on how fast you actually hit it, it might be getting caught on something. They are quite taught!
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    ok ill have to have a look under the bonnet and see if anything is hitting the cable if i can find it lol, im glad audi made it easy to work on lol.
    alan
    filipharvey's Avatar
    Amusing Tagline
    Aug 2006
    Fakenham, Norfolk
    518
    Smile
    I have had the same thing on my '95 1.8. Couldn't say what causes it, but I do know that the wish bone bearings are on their way out on that side. Mine is on the drivers side tho!
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    is it an auto? probably throttle cable to auto box if it is
    just a little a6
    jcb
    Sep 2005
    uk
    4,077
    mine sometime has an involutary blip that I can feel with my foot, pedal just moves a couple of mm, no obvious revving. doesn't bother me, tends to be when stationary
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    yeah mine an auto
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    there is a throttle body cable for the autobox for kickdown could be caught check around the gearbox that cables aren't caught
    just a little a6
