jrleech
Here's the story.....
Took battery and tray out to remove blockage from drain plug, re-fitted battery and alarm/immobiliser kicked in.
Didn't have a remote for the alarm, so today had installer come and remove it and fit a Cobra Cat 1 system. All seemed well, car now starts!!
Problem is, when I put the clutch in or sit at a junction, the engine idle searches a lot before settling. If I rev the engine then lift off, it'll drop to 500rpm, then 1200, then 600, then 1100 etc...., eventually settling back to normal.
Sometimes it'll dip so far it stalls itself.
I've read some posts here that point to the lambda sensor, but it seems too much of a coincidence.
Is there a 'learning system' that has got messed up? After having the battery reconnected, the first hour of the car's running time was spent at idle... could this have caused it?
The installed assures me that his installation couldn't affect the idle, (he's immobilising the fuel pump power and ignition circuit).
Any ideas? Or is it likely to be the 02 sensor?
Thanks,
Jon
Thanks,
Jon
