Results 1 to 7 of 7
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Throttle body adaptation
    Good evening fellas,
    As the title says, I was wondering exactly what this entails? Planning on giving the old throttle body the cleaning of it's life in the next few days but also want to do the whole kit and kaboodle and do the adaptation too.
    I've done a search (to no avail) and checked the FAQ section but not found any specifics of how/what to do.
    Any chance someone could enlighten me? Does it include VAGcom?
    Thanks in advance,
    Justin
    mas
    Jul 2005
    n yorks
    128
    Re: Throttle body adaptation
    I think there is some info on the ross tech site.
    I also think you need vag com or a vag tool.
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Cheers Mark, will have a looky there. Had a sneaking suspicion that it involved using VAGcom!!
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Cheers again Mark, managed to find this on Ross-Tech:
    linky
    Gonna give the TB a clean and then find someone with VAGcom to sort the alignment.
    imported_mc119856
    I've been considering having a go at this, let us know how you get on.....
    Jan 2007
    13
    On my 1997 1.8SE the throttle will align itself if you turn the ignition on for at least 6 or 8 secs without starting the engine or touching the accelerator pedal. After this time you can hear the throttle motor running and when it stops the adaptation is complete.
    Jan 2007
    13
    Sorry for resurrecting such an old post. Thought it useful anyway.
