Chris NottEM Tuning
    May 2006
    Lancashire, UK
    40
    Water under battery tray & brake master cylinder....
    I was just washing my car and when I lifted the engine lid I noticed a load of water (about 3 litres!!).
    It was under the battery tray, brake master cylinder and around where the coolant hoses go to the heater matrix (about half an inch deep). Took about half an hour to sponge it all out.
    It's obviously designed to get wet, as the runoff at the bottom of the windscreen dumps the water there. I'm sure it's not designed to stay full though,
    I'm guessing there's a drain hole or two and they're blocked. Does anyone know where they're located??
    Thanks,
    Jon
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: Water under battery tray & brake master cylinder....
    Drain Hole is located on the left hand side of the Battery(looking down) probably blocked
    May 2006
    Lancashire, UK
    40
    Thanks.... I'll have a good hunt around in the morning.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    There is a drain hole with a big rubber grommet thing located right underneath the battery tray that is meant to act like a sort of primitive one-way drain valve....
    Thing is, it easily gets blocked up with rubbish/slime/crud, once battery and tray are removed its a 2 minute job to remove and clean grommet....did this a few months ago with no probs since.
    [img]/ubbthreads/images/graemlins/wink.gif[/img]
    May 2006
    Lancashire, UK
    40
    Nice one, thanks. Hope I can remember my battery code!! It was like a lake in there yesterday!!
