[ QUOTE ]
i had mine done by autotronics in leicester cost me £40 for a re-gas now its ice cold before i got it done it wasnt that cold nows it perfect some times i gotto put the econ button to make it go a lil warmer. let me know if u want the number.
[/ QUOTE ]
What temp are you setting it at? Surely, if you're finding it a bit too cold, you should raise the temperature setting a bit, not switch it off!
Don't forget, you're not trying to freeze-dry yourself. The idea is to set it at a comfortable temperature, say 20 or 21 degrees, and then leave it to its own devices.
