    Mar 2006
    Chester
    79
    What\'s this bit do?!
    Just replaced the N75J valve on my 1.8T. To get to it I had to temprarily remove a black circular part (approx 5cm diameter)... a rubber hose from the middle of it joined the air intake, and another hose joined onto a metal pipe (which looked like a breather pipe), fitted along the side of the cylinder head.
    What is it?! [img]/ubbthreads/images/graemlins/idea.gif[/img]
    When I removed it some oil poured out - is this to be expected? Also, one of the hose clips was very loose.
    All back together now, and seems to be pulling more smoothly.
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: What\'s this bit do?!
    Sounds like something to do with the PCV (positive crankcase ventilation) to me, they normally have a habit of collecting a little oil, nothing to worry about I don't think.
    Matt
