Volks AutosBadger5
    imported_TDi_Singh
    Horn Fuse keeps blowing
    Can anyone help me!!!! [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    My horn does not work.
    This happened a year or so ago and I found the fuse had blown so replacing this solved the problem.
    This time, the fuse has blown and replacing it with a new one only blows as soon as you press the horn.
    Any ideas???? [img]/ubbthreads/images/graemlins/shocked.gif[/img]
    MOT coming up soon! This is a fail!
    Your help would be much appreciated.
    For info: 2000 A4 2.5 Tdi
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,628
    Re: Horn Fuse keeps blowing
    Disconect the horn unit, replace fuse and press again...if fuse blows there would appear to be short in the wiring loom somewhere, if so, a case of tack and trace!
    If it doesn't blow, then the horn unit could be fault.
    May even be bad connections / corrosion in the connecter. Clean all contacts up.
    Dan
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    Dont press the horn... !..
    [img]/ubbthreads/images/graemlins/dancing.gif[/img]
