[ QUOTE ]
(oh yeah - have you had vag-com on it ? that can identify which wheel is causing the problem - but not if its the reluctor ring). have to remove the cv joint to check it.
[/ QUOTE ]
Yeah, had vag com on it. Only fault is EGT Sensor.
So probably down to an ABS ring somewhere?
Looks like a process of elimination!!! THink I'll start at front wheels.
If a sensor is faulty, would it definately show up on vag-com?
Dan
