EM TuningSky Insurance
Results 1 to 8 of 8
    spinaltap's Avatar
    Oct 2005
    UK
    27
    Car battery suddenly draining!
    The battery in my A4 is the original one as far as I know, so just over 6 years old. After having no problems with it over the last year or so, it could barely start the car today with the meter barely above 8v. After taking it for a long run it was staying at about 12v after switching engine off, but a few hours later it's back down to under 10v now. Could the battery have suddenly died overnight or could there be another electrical problem draining it?
    Thanks for any advice ...
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: Car battery suddenly draining!
    Battery sounds goosed ,,,,,,,happens like that ..have you checked the water levels in the battery?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Prob one sell died.
    Jun 2003
    World of my own
    9,813
    6 years is about right, get it changed
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Like Andy says, six years is time to change.
    I've had that happen, where a battery has seemingly discharged overnight, but in fact has died. If you charge it up, it might take on some charge, but the same will probably happen in a couple of days, because ultimately the battery has reached the end if its life.
    I don't know if it still applies, but when it happened to me, I was abe to save money by buying the replacement from a VW rather than an Audi dealer.
    Jun 2004
    Northants
    126
    Yep. def the battery, mine just went and the car is six years old. Can't complain as the car has now covered nearly 160K!!!!
    spinaltap's Avatar
    Oct 2005
    UK
    27
    Good to hear it's just battery! How easy is it to get it out to check levels/replace etc? It looks like I've got to remove the whole plastic section above it that goes over base of windscreen, running width of engine bay, or isn't it that bad?
    And how much should battery be? The one in Halfords was 70 and looking online I've seen no-brand ones for 50.
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,600
    You will have to remove the plastic shroud.
    I bought my new battery for my A6 from VW in the end.
    Bought a battery from Halfrauds "yes sir this is definately the battery you want!"...went to fit.....about an inch longer than original and wouldnt fit.
    Went to a motor factors "yes sir this is definately the battery you want!"...went to fit.....about an inch 1/2 longer than original and wouldnt fit!!!
    Got peeved off and went to vw. Got nice discount off my mate and a genuine battery that fitted perfectly! [img]/ubbthreads/images/graemlins/ok.gif[/img]
    So moral of the story, check your battery size BEFORE buying a new one. May not be the same on an A4 but an A6 battery clamps couldn't be adjusted to fit bigger/smaller batteries.
