AH FabricationsChris Nott
    Jan 2006
    Deal, Kent
    468
    Leaking exhaust gas - farting noise!
    Hi, noticed for quite a while now I have a strange exhaust noise under acceleration.
    But the other day I accidentally put my foot down too much before the car was properly warm, and it made a louder kind of noise where exhaust gas was escaping.
    Is it likely to be either a knackered cat, leaking cat to downpipe joint or has anyone experienced loosening manifold / turbo studs.
    Car has done 115k
    Any thoughts appreciated.
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Leaking exhaust gas - farting noise!
    Drop the turbo, and check teh gasket - these are prone to failure! Also check all other exhaust gaskets.
    RIch
    Jan 2006
    Deal, Kent
    468
    Looks a right ***** to get in there to drop the turbo!
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,698
    Sometimes the cats actually snap where they bolt on to the turbo check that.
    Can you not get someone to (while the car is cold) cover the exaust pipes while you feel where the fumes are blowing out?
    ...Watching you!
    Earlsfield, London
    5,087
    Not so much drop the turbo, but unbolt it and drop it an inch or so to replace the gasket (or atleast check it). Check the more accessible ones first.
    Rich
    Jan 2006
    Deal, Kent
    468
    Yeah OK. Been wanting to de-cat it anyway, but not got around to finding a suitable pipe yet.
    I also meant to say that the noise is worse when cold, I said when I accidentally put my foot down and used the turbo when still cold! Tut Tut - (Is it me or just that dbw cars are so sensitive to right foot movement in the lower gears?) When she's warmed up the noise is almost gone, hinting that the heat expands whatever is loose.
    When I look is it easy to get at the actuator rod, mine was re-mapped almost 2 years ago and feels a bit flat in 3rd and 4th for a 200bhp-ish car.
    I think the standard exhaust makes a strange noise under boost, always has, unless it is the cat dying! Why are there never bargain performance exhasuts on ebay?!?!
