Sky InsuranceEM Tuning
Thread: OBDII ?
    Jul 2014
    OBDII ?
    I found a socket in the rear ash tray. Is this OBDII or some other protocol? My car is a 1999 A4 B5 1.8 non turbo.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    its OBD with a vag specific protocol.
    You need a VAG specific diagnostic tool like VCDS
    TD5 Land Rover Defender build
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Yes it the diagnostic port to scan for faults etc
    Jul 2014
    Are the readers readily available like the ELM devices on fleabay or is it just better to go to a garage? I dont have anything wrong at the moment, but just like to be prepared.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    the bluetooth ELM units will work but mainly used for basic data logging.
    Its best to get a VCDS cable.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    "Stick a V8 in it!"
    15,388
    yeh, cheap ebay vcds cable is a good starting point, lets you do basic stuff and lets you get a handle on the software etc.
  1. OBDII Diagnostic Software off eBay
    By DeeBeeS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2007, 19:48
  2. Where is your OBDII port on your S3
    By sitrials in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2007, 23:42
  3. OBDII Codes
    By imported_kbininger in forum Volkswagen and other VAG
    Last Post: 19th April 2006, 21:29
  4. Looks like APR have sorted the 2.0TFSI OBDII remap....
    By Cupramax in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2005, 11:26
  5. 2.0tdi ECU OBDII remap - It's here!!!
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2005, 14:06
