Badger5Sky Insurance
Results 1 to 12 of 12
    flat out
    Feb 2014
    london
    6
    Question what calipers will fit b5 s4 ?
    Hi, it may well have been posted before, but I can't seem to find it. What other Audi calipers are a direct replacement for a b5 s4 1998 ? Have heard that any b7 chassis audi running 321mm discs will mount straight up but looking for some clarification on this. On another note, what are the best pads to run on the standard calipers ? the brakes are pants LOL.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Ferrodo pads or padgid's. I went padgid route but will be swapping to ferrodos at next pad change.
    The B7 2.0T has 320mm fronts iirc or you can go B6/7 345mm S4's, anything on the VAG range with larger caliper spacing should go on with little effort.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,380
    Yeh direct swap you can use the B7 320's or A6/Allroad models also used the same 320mm setup.
    The stock S4 calipers are a bit ****, and you will struggle to get decent pads for them.
    TD5 Land Rover Defender build
    flat out
    Feb 2014
    london
    6
    Cheers for the replies, been scouring the net all day trying to find some decent pads for the stock set up. the pagids are stock oem spec aren't they, was looking at Ferrodo 2500 but they don't do fronts, or not that I can find . . .which Ferrodo's do you recommend ? chers. might have to swap for some b7 calipers just to open up the options a bit
    "Stick a V8 in it!"
    15,380
    Yeh if your wanting "fancy" pads then just change them.
    should be plenty pad options for the B7/A6 320mm ATE caliper
    flat out
    Feb 2014
    london
    6
    I don't want fancy pads, just to stop !! lol
    Aug 2010
    3,138
    The 320mm brakes use the same pad as the B6/7 S4 iirc so should be easy to find ds2500 id say only get them if your going to track it if not ferrodo premiers will do just fine for every day driving.
    If you do get pagids they tend to go a bit crap after a few months hence why il be switching to the ferrodo's as mine seem to have lost there initial bite.
    "Stick a V8 in it!"
    15,380
    Try the ATE calipers and some Ferodo Premiers and see how you get on!
    flat out
    Feb 2014
    london
    6
    Cheers all. Do the ATE calipers bolt straight up to the b5 s4 struts ? Thanks again
    "Stick a V8 in it!"
    15,380
    yep!
    "Stick a V8 in it!"
    15,380
    flat out
    Feb 2014
    london
    6
  1. what springs will fit an audi a3 in the back
    By 20v-turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2011, 08:38
  2. what engines will fit??????????
    By tonya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2010, 16:43
  3. According to This S3/R32/LCR Calipers will fit 2WD A3s.. Or will they?
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2008, 00:53
  4. What wheels will fit over gt3 calipers????
    By scott_johnson in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2008, 08:53
  5. CAN ANYONE TELL ME WHAT WHEELS WILL FIT MY CAR?!
    By claire in forum Classic Audi Forum
    Last Post: 9th April 2004, 13:39
