EM TuningMonster Motorsport
Results 1 to 9 of 9
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    Cruise activation problem
    Can't get my cruise to actually 'work'.
    I have fitted the cruise switch and loom, done the 11463 code in VCDS, checked measuring blocks, all showing as working, cruise showing as activated in VCDS, also just to make sure deactivated cruise (16167 code) and it deactivated showing 255 where it should if no cruise on car.
    It has been reactivated again, but when I press 'set' it doesn't set.... Doing my head in now, any clues? What am I missing?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    You need to look at the stalk outputs in VCDS, its probably bad contacts in the switch.
    TD5 Land Rover Defender build
    Jan 2011
    279
    I did check the stalk outputs, they all give a 1 when pressed, the only thing (I was driving) I didn't notice was the 1 for the latching which would be a 1 second from the right
    "Stick a V8 in it!"
    15,390
    What i found with my stalk, was that moving it from the "on" to "set" position flipped the "set" bit as expect, but the "on" bit would flicker.
    If you were very gentle with it it would mostly work.
    What i also found was that if you released it a bit too sharply, when it snapped back to the "on" position it would flick to "off" momentarily, which cancels the cruise.
    my brother had an issue with his S4 where it wouldnt work at all. After i hooked up vagcom and went for a run i noticed the clutch switch was showing the clutch was depressed. I looked down and his foots sat resting on the clutch pedal. Faulty brake light switch can also cause it.
    Jan 2011
    279
    I've heard about that problem with stalk contacts, it didn't seem to be flickering tho. I could try another stalk.
    "Stick a V8 in it!"
    15,390
    have you checked the clutch and brake outputs in VCDS and ensured they're sensible?
    I think its on the same screen as the stalk.
    Jan 2011
    279
    Yeah, brake and clutch outputs are correct too. I got my mate at Audi to send me a .pdf of their instructions, and the checks. Can't post it on here, I'll try taking screenshots see if that works. He also said the ECU can be stubborn to take the codes and work, but we were at it for a while yesterday.
    Jan 2011
    279
    Jan 2011
    279
    There's loads more, just checking what the quality is like, it's from ElsaPro
  1. cruise control problem
    By bez101 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th November 2012, 21:10
  2. Cruise Control Problem, just not having any luck with this car at al
    By zollybosher in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th October 2012, 21:00
  3. Retrofit cruise control problems help
    By flippin82 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th June 2012, 23:26
  4. Retrofit Cruise - ESP problem
    By sijones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2011, 12:40
  5. Please help cruise control problem 8P
    By Troubs12 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2009, 22:58
