Cruise activation problem
foursprungdugtechnique
Perth, Scotland PH1 2BN
Can't get my cruise to actually 'work'.
I have fitted the cruise switch and loom, done the 11463 code in VCDS, checked measuring blocks, all showing as working, cruise showing as activated in VCDS, also just to make sure deactivated cruise (16167 code) and it deactivated showing 255 where it should if no cruise on car.
It has been reactivated again, but when I press 'set' it doesn't set.... Doing my head in now, any clues? What am I missing?
I did check the stalk outputs, they all give a 1 when pressed, the only thing (I was driving) I didn't notice was the 1 for the latching which would be a 1 second from the right
What i found with my stalk, was that moving it from the "on" to "set" position flipped the "set" bit as expect, but the "on" bit would flicker.
If you were very gentle with it it would mostly work.
What i also found was that if you released it a bit too sharply, when it snapped back to the "on" position it would flick to "off" momentarily, which cancels the cruise.
my brother had an issue with his S4 where it wouldnt work at all. After i hooked up vagcom and went for a run i noticed the clutch switch was showing the clutch was depressed. I looked down and his foots sat resting on the clutch pedal. Faulty brake light switch can also cause it.
have you checked the clutch and brake outputs in VCDS and ensured they're sensible?
I think its on the same screen as the stalk.
Yeah, brake and clutch outputs are correct too. I got my mate at Audi to send me a .pdf of their instructions, and the checks. Can't post it on here, I'll try taking screenshots see if that works. He also said the ECU can be stubborn to take the codes and work, but we were at it for a while yesterday.
ImageUploadedByTapatalk1403858918582472
879
732
723
21
2K
