Sky InsuranceBadger5
Results 1 to 11 of 11
Thread: Exhaust problem
    Aug 2009
    Dorset, UK
    176
    Exhaust problem
    Got a 2,8 V6 Q it has full miltech system, but the blowing is from the flexi joints from the down pipes to the CAT. Can you get just these flexi joints replaced? The rest of the down pipe/cat section is fine, no problems. Just the flexi join on one side, but the other side looks like it is about to go too. Any advise on how to sort the prob and approx costs will be good. Thanks
    Nov 2013
    27
    Best to take it to an exhaust place, could probably weld in a piece of flexi, can't see it costing a lot .
    Aug 2009
    Dorset, UK
    176
    Thanks Jonny, anyone know if this can be done in situ ? there is about 25mm clearence at the tightest spot.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    The shop did my 1.8T flexi in situ because the guy was a lazy bast and couldnt be arsed taking it off like i'd asked him to.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,091
    I had one replaced on my 1.8t before going Miltek and it cost me 80 quid all in.
    Life begins at 140mph
    www.passionford.com
    Aug 2009
    Dorset, UK
    176
    Thanks guys, I went to my local exhaust place the guy said he would be happy to give it a go only if I get the two flexi joints with the end bits/sleeves. Can anyone tell me where to get them I am struggling to find them on the internet
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,091
    Try giving R Tech located in St Albans. 01727 790100. They were the chaps that sorted mine out but they may not do supply only
    www.passionford.com
    "Stick a V8 in it!"
    15,385
    the flexis are available on ebay:
    2.5 exhaust flexi | eBay
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    if he cant get the flex and says he will have a go.
    then I would be finding someone else that says not a problem sir that will be ££
    Aug 2009
    Dorset, UK
    176
    Thanks aragorn, do you recommend the weld in ones or the clamp ones? Clamp ones will be easy to fit but are the weld ones better, (they will have to be the correct length but there can be some play with the clamp ones) is that right
    "Stick a V8 in it!"
    15,385
    you'll need the weld on ones, theres not enough streight pipe to clamp one in, as the flexi sits on a corner.
  1. Exhaust problems
    By chiddles in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th November 2009, 20:47
  2. Exhaust problems
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2009, 12:03
  3. Exhaust problem?
    By Just Plain Old in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th July 2007, 14:13
  4. A3 T Quattro: problem with exhaust or transmission rattle
    By BADDave in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2005, 11:21
  5. Next Problem: Exhaust drone/boom 3000rpm
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2003, 17:39
