Volks AutosJMB Retrofits
Results 1 to 12 of 12
    Jun 2014
    Cheshire
    10
    Ongoing starting fault A4 2.6
    About nine months ago my starting woes began. I came out to the car turned her over and unbelievably as soon as it fired, ran for 1 second then cut out. It did this another two times and then started with a bit of pedal.Over the course of the next few months it continued to do this,all be it completely intermittently.It also did it when it was hot. Well last weekend it did it again but this time failed to start at all. I'm just in the process of changing the coolant temperature sensor as people have indicated that this could be the fault. The last time the codes were checked at the garage i was informed that the sensor was iffy. I'm hoping this could be the answer but just can't see it myself. Any other info would be great.
    Cheers all
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    Its probably the immobiliser.
    It allows the engine to start then cuts it off after a second or two if it cant verify the key.
    What is the immo light on the dashboard doing when the car wont start?
    TD5 Land Rover Defender build
    Jun 2014
    Cheshire
    10
    I didn't know that there was an immobiliser light but will check it out after iv'e got the new coolant sensor fitted and update. Thanks
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,072
    I'm with aragorn, bet it's the wiring to the pick up ring. Parts are availlable from the dealer for a couple of quid to sort it
    Life begins at 140mph
    www.passionford.com
    Jun 2014
    Cheshire
    10
    This is sounding better news than i thought
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,072
    Next time it does it look for the yellow light on the dash with the car and key flashing
    www.passionford.com
    Jun 2014
    Cheshire
    10
    I'll do that. It was just my worry that the ECU had imploded as it did at 18000 miles and the cars just turned 38000
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,072
    I'm on 173,000 miles and most bits are still the originals, 100,000 of those are miles I've done too
    If it does do it release the steering column and move it up and down (or down and up) and then try restart.
    www.passionford.com
    Jun 2014
    Cheshire
    10
    Sounds a good plan before i take anything apart.. Cheers Oranoco.
    100000 miles
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,072
    NP.
    Yep 100k and it's still on the original clutch, turbo lol. More of a miracle when you know I do this with it too...
    www.passionford.com
    Jun 2014
    Cheshire
    10
    Looks like fun.. Still the best looking car that broke the mould in my opinion
    My things motorbikes to be honest but anything with an engine sits well with me
    Jun 2014
    Cheshire
    10
    Bit of an update.
    Got round to fitting the coolant temp sensor(no skin left on the back of me my hands)
    Went to start and exactly the same thing happened(cut out after a second).
    Loosened the wheel, gave the column a couple of sharp up and downs, went to start and bugger me, Bingo. No issues, runs beautifully.
    An immo fault seems to be the issue which i will look at shortly. The upside of replacing the sensor has cured the wandering RPM so i'm really happy about that, just need to fix the immo but i'll monitor it over the next few days.
  1. Stop/Start Fault
    By DavieG87 in forum New A3/S3 (8V Chassis)
    Last Post: 20th December 2013, 21:54
  2. Replies: 9
    Last Post: 7th February 2012, 18:20
  3. Fault codes galore, but an ongoing problem exists. Help!!!
    By Seansy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2011, 18:07
  4. starting fault
    By lame83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2010, 17:09
  5. A6 Quattro 2.5TDI Starting/Fuel fault
    By The Fiend in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th September 2009, 22:51
