EM TuningBadger5
    Jan 2006
    AT Las
    17
    Rear wash wipe problem........
    Hi,
    My rear wash wipe's not "washing"! wiper works and I can hear the motor for the wash.
    I think the pipe's come undone at a T piece or something, as the wash solution seems to be leaking out somewhere in the tailgate
    So, how do I remove the tailgate trim to start tracing it back?
    Any ideas?
    I would have thought it's the same process as removing the trim to replace the high visibility brake light.....
    Thanks in advance [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Dano
    mas
    Jul 2005
    n yorks
    128
    Re: Rear wash wipe problem........
    Undo the couple of visible screws around the rear screen and the main panel pulls off.
    If you open the right hand pocket / flap the pipe can be accessed in there.
    It also runs across the front passenger footwell (which is where mine leaks). What seems to happen is that the pipe gets hard and it leaks from one of the joints. Or from the wiper motor itself.
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Take a look at this thread from a while back; its primarily about the A3, and there's a lot to read, but I had the same problem with my A4, and as well as a bad water-pipe connection on the wiper motor itself there was also a problem with the wiper motor...
    Read it all and am sure you will sort it out.... [img]/ubbthreads/images/graemlins/wink.gif[/img]
    http://www.audi-sport.net/ubbthreads/sho...true#Post366843
    Jan 2006
    AT Las
    17
    Thanks for the heads up - have got in touch with a few of them to get started on it this weekend [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Once it stoppes blummin raining!! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    DanoS4
    Jan 2006
    AT Las
    17
    Also "Thanks" to mark [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Will have a look this weekend [img]/ubbthreads/images/graemlins/wink.gif[/img]
    DanoS4
