Its on, one of turbo bolts was ready for snapping so retightened and applied some heat that evetually budged it then when i came to top up the coolant and removed the cap it started to run out from the turbo area which i think is the block to turbo pipe, new oil and filter done aswell got the wastegate just cracking at around 10psi, found both n75 to turbo pipes were shot went to do the 3" maf/injectors but didnt have a security Torx 20 to swap the sensor out to the bigger MAF. Took about just over an hour to remove then about same swapping bits over on the bench then building back up then an hour later more or less done forgot to put the support bracket on D'OH then the coolant issue just p***ed me off and work was closing in 30mins so thought i will tackle it tomorrow with a fresh head lol !!
Took one of the service cars (skoda rapid 1.2TFSI) its far from rapid lol so going to take my vagcom to see what MAF figures im seeing hopefully some what close to the 230hp your seeing.
