Chris NottBadger5
Results 1 to 29 of 29
Thread: Failed MOT
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Failed MOT
    My A4 has just failed the MOT on drivers side front upper control arm ball joint, it's the one that is closest to you as you look into the wheel arch and I believe attached to the right hand side at the back.
    Any idea of how much a replacement is going to cost me? I'm gonna try and get an Audi one if I can. Are they much of a job to do?
    Not looking forward to being car-less for a few days now!
    Matt
    Jun 2003
    World of my own
    9,813
    Re: Failed MOT
    Makes you fume when you see some of the scrap heaps on the roads with supposed MOT passes, especially vans & lorries.
    Yes my 97 a4 failed on exactly the same thing, luckily the VAG specialist I use was able to get one same day so wasn't too much of a pain.
    The part was 42.50 + approx 1 hour @ 40 per hour to fit as I got them to do both sides upper & lower for a total of 260 incl VAT.
    Expect to pay double at a dealer.
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    Thanks for that, won't be getting done by a dealer, I'm going to see my mechanic in the morning to arrange a service anyway, so will get him to quote that too, just hope that I can get it done fairly quickly I hate being without a car, feels so wrong!
    Jun 2003
    World of my own
    9,813
    Re: Failed MOT
    I would suggest not letting your MOT run out before getting it renewed, but that would be hypocritical of me as I seem to do the same thing every year, it always catches me out.
    With the new online MOT system you should be able to set reminders and have them emailed to you way before it expires, but that would be too helpful.
    imported_VaulterTim
    Re: Failed MOT
    We get a reminder before our Tax runs out... I'm sure VOSA could employ a similar system... But like you say, that would be far too helpful! [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    The old ticket runs out on tuesday, I'm not sure on whether I can still drive it until then or not really? I would assume that the failure would void the current MOT? Anyone shed any light on that?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Failed MOT
    [ QUOTE ]
    [/ QUOTE ]
    You've got a valid MOT...So as long as you get it fixed before it expires, its OK.
    RIch
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    Thanks for that, don't think i'll be able to get it sorted before tuesday, but at least I can use it until then,
    Jun 2003
    Hythe, Kent
    1,180
    Re: Failed MOT
    What mileage has the car got on it? just out of interest.
    Kev.
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    just over 90k
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Re: Failed MOT
    [ QUOTE ]
    Matt
    [/ QUOTE ]
    Don't want to put you on a downer at all but would recommend that you either get a garage to do this for you or at least someone who has oxy-acetylene equipment......
    There is a transverse pinch bolt that secures the balljoints of the arms you're referring to to the suspension leg upright.
    Just undo this pinch bolt and take off the suspension arm.....yeah right.
    I needed to renew an outer CV boot on my car a few months ago and as per the manual needed to get the suspension leg off in able to get at/renew the boot.
    That damned pinch bolt wouldn't budge ; I had already got a replacement bolt as my local main stealer casually mentioned that they were often a bit of a swine to get out.....
    I tried to heat the bolt with a propane gas torch but despite careful use of an asbestos mat still managed to singe both balljoint rubbers of the 2 suspension arms [img]/ubbthreads/images/graemlins/burningmad.gif[/img] .
    Ended up having to remove the suspension arm mounting on the inner wing (held in place by 3 nuts) and remove the whole front suspension leg.
    Clamped in a vice on my workbench I had to apply loads of heat and knock the hell out of that pinch-bolt before it would move at all......
    If I had had access to a proper source of heat initially I wouldn't have had so much aggro...am dreading the day I ever have to get the offside suspension leg off my car now....
    Have since discovered that this pinch bolt is also found on the Passat (same set-up) and is infamous for seizing on that model too....
    [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Feb 2006
    cardiff
    21
    Re: Failed MOT
    Take the car to a leniant MOT station, evrybody knows a friendly MOT inspector, obviously if the joint is knackered I would change it.
    hope this helps Jason
    Jun 2003
    World of my own
    9,813
    Re: Failed MOT
    Is that under "L" in the Yellow Pages?
    Feb 2006
    uk
    Re: Failed MOT
    i had that exact same problem when i did my own pre MOT check, changed it myself quite easily. DIY toolbox and a bit of my own time and i've saved a fortune,these car's are not rocket science as the the badge lead's you to believe.....
    Charlies604's Avatar
    Jul 2005
    Plymouth/Taunton
    203
    Re: Failed MOT
    I did those bolts to change to coilovers.... they were an ass BUT i got them out with WD40... hammer and bar.
    If you heat the bolt it will expand and wont move anywhere!
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    Thanks for the info guys.
    Car is booked in for monday morning for a service and getting the joint done, so will be sorted soon [img]/ubbthreads/images/graemlins/smile.gif[/img]
    mas
    Jul 2005
    n yorks
    128
    Re: Failed MOT
    "You've got a valid MOT...So as long as you get it fixed before it expires, its OK."
    Errr, no its not. You no longer have a valid MOT. MOT failure means that you are only ok to go to and from a repairer and mot testing station.
    Thats always been the case but wasn't ever a problem in the pre-computer days because nobody could tell that you had failed. Now that the mot system is on line the police and the roadside dvla cameras can pick you up on it.
    OK its unlikely that you will get picked up on it, even if stopped and given a producer it would need a keen bod at the station to go away and check Might be a problem if you have an accident
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    Thanks for clarifing that [img]/ubbthreads/images/graemlins/smile.gif[/img]
    I've only got to drop it off at the garage tomorrow evening now, so it won't be used anymore before being fixed, Then i'll have to sort a retest out. Hopefully all will be good by the middle of the week [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Re: Failed MOT
    [ QUOTE ]
    [/ QUOTE ]
    If you have a partially rusted/corroded fastener/bolt etc a mechanical attempt to remove it will often result in the said item shearing.....heat will very often cause enough expansion between the surfaces to break any corrosion and allow the item to be dismantled successfully......
    Have lost count over the years where heat has successfully shifted a stubborn fastening!
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    I'll second that! Had a seized slide pin in a brake caliper once, got a bit of heat into the caliper and BANG out flew the pin! Putting a nice dent in the shed wall about 6 ft away! Glad no one got in it's way! [img]/ubbthreads/images/graemlins/smile.gif[/img] Heat is gooood!
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    Well, car is now fixed, had it serviced and the control arm fitted.
    Only trouble is the soonest MOT re-test I can get is thursday! So car has to sit in my garage now until then [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Ahh well, at least it's sorted [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Miller's Avatar
    Dec 2005
    S Wales
    13
    Re: Failed MOT
    Pleased to hear your car is sorted. What was the price of the repair?
    Top arm, genuine Audi, from Vagparts is 58.31 incl VAT and post but I notice Clickapart on Ebay is selling top arms for 30 incl post.
    Apparently they are "e-approved"; a very good price but has anyone tried them?
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    Cheers [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Overall came to just under 200, but I had to buy the control arm in advance at a cost of 55, which was from Eurocar parts, did want to get an Audi one, but couldn't get one in time. Just gotta fork out 20 for the re-test now, joy!
    jcb
    Sep 2005
    uk
    4,077
    Re: Failed MOT
    thought retests were free
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: Failed MOT
    They are within a certain time limit
    Jun 2003
    World of my own
    9,813
    Re: Failed MOT
    "Overall came to just under 200" - Ouch, glad I've found a good specialist.
    Autotechnik did mine, both sides, top & bottom for 260 with OEM parts.
  28. #27
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    That was 200 including a full service so, not too bad at all really [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Re-tests are no longer free due to the system being computerised now, they have to do a full test again, even though the work has quite clearly been done and the rest of the car is fine anyway! So the bloke will look under the car to see the new arm, then click all the other boxes on his computer as ok, then sit about for the rest of the hour! Gotta love modernisation!
  29. #28
    Jun 2003
    World of my own
    9,813
    Re: Failed MOT
    Ahhh, that's more like it.
    The place I use only does MOT's, there's at least 3 guys running it and they can only really do one car at a time. I'm amazed they make any profit at 40 per hour between 3 of them + all the overheads and they never seem that busy. I'm sure it's a front for money laundering or something more sinister.
  30. #29
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Re: Failed MOT
    Just been back for my re-test, it passed! wooo! got my car back!
    They did it in 10 mins and only charged me a tenner, apparently he managed to 'fast-track' it, instead of doing a full test again, very handy!
