EM TuningMonster Motorsport
Like Tree1Likes
  • 1 Post By shineydave
Thread: Fuel gauge stops working
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    My fuel gauge is playing up along with the 'creep' its no started to show empty after switching the car on and off it only happens just under a 1/4 of a tank and when i next get in the car the fuel light comes on and it reads empty i tank the car every fill up so dont just throw a tenner in here and there if i do i will throw £20 in at weekends.
    is it time for a new fuel gauge or can they be repaired ??
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    there's a wire that links the float to the body on the sender in the tank. mine went last summer, just pop the sender out and solder a new piece in. I used the conductor from an old set of test leads as they're nice and flexible
    PAULF likes this.
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    matt66604's Avatar
    Dec 2013
    Aberdeen
    52
    would that cause an intermittent fault in 17- instruments - fuel level sender open circuit/short to ground - intermittant ?
    Aug 2010
    3,138
    Probably not as it would just probably think its empty but i will check anyway never thought of checking the faults, sunday i was on literally empty after dit coming down from just over the 1/8 bar when the light comes on got to tesco as the needle was off the gauge and it only took £56 iirc got in the car and it showed 3/4 of a tank and wouldnt take no more drove 2 or 3 mile down the road and it crept up to just under a full tank, going to look at it this weekend if i get chance, from memory can you just remove the lock ring and gain access to the gauge unit and remove it fairly easy ie with little tools dont want to be carting tools home from work as i always forget to take them back lol
  1. Fuel Gauge Stop Working Resloved
    By starmix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2012, 22:32
  2. Temp gauge stopped working?
    By aterro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th May 2011, 16:49
  3. Fuel Gauge not working, Audi A3 8P :)
    By a5hl3y2k6 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2011, 13:46
  4. Fuel gauge not working
    By jeffers999 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2007, 05:02
  5. Fuel gauge not working correctly A6 2.5TDI
    By K7ERG in forum Classic Audi Forum
    Last Post: 16th April 2007, 20:10
