I have a slight leak at the back of the car, need to get it sorted before MOT. Anyone had to replace pipes, and what with? I was going to go to Pirtek and get fuel hose and clamps.
They're metal pipes, I had repaired the front from the first rubber mount where it had rotted to about 6 inches up the bulkhead with 10mm internal diameter rubber fuel hose and clamps.
The whole lot, front to back, flow and return is now rubber hose now, all sorted.
£25 out of Pirtek
They're fairly safe running in the existing fuel line clips, they're also pretty thick sidewalks and braided. The MOT tester was happy enough, and I don't rally the car, it's also SE and as high as a monster truck anyway lol
