Monster MotorsportEM Tuning
Results 1 to 8 of 8
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Add Dimokslis on Facebook Add Dimokslis on Google+
    TRW brake pad wear sensor pins wrong
    Hi folks,
    Just installed new front brake pads yesterday and light on the dash did not go away, so went to check connectors today and found this.
    Picture - http://img834.imageshack.us/img834/1205/1vdpn.jpg
    Has anyone experienced that?
    Could be that if front brakes were LUCAS? As my ones are ATE and car connector pins are opposite to those on the brake pads.
    But I doubt that Audi changed pins just for different brake suppliers...
    Or its just TRW made it wrong???
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    I'm not sure what your pic shows? the plug and connector look to match to me?
    TD5 Land Rover Defender build
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Look inside of the connector, pin1 and pin2 on the brake pad connector do not match with car connector's pin1 and pin2. Where on the old brake pad numbers matched with car connector's numbering and everything worked perfect.
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Pin layout shouldnt be a problem as your only closing the circuit, when the pads get low it becomes an open circuit thus bringing the light on, check the connection i no that my fronts are zip tied together as there a crap connection but there pagid pads and i had to do it with the mintex on the 312mm setup aswell !!
    "Stick a V8 in it!"
    15,390
    As yes, i see now. As Bradderz says, its not a problem, as its just a loop of wire.
    I've just unplugged mine where it goes into the car, and shorted the wires.
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Thanks, gonna have a look at it tomorrow, must be a fault in cars connector or harness.
    I really thought is more complicated inside of a wear sensor.
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    255
    Quote Originally Posted by Dimokslis View Post
    Both my cars have thrown up fault codes on the brake pad sensor at one point or other. They get brittle with age when you're replacing pads, even trying to disconnect them is a black art! Check the pins aren't bent and fit snug. In addition the wiring isn't broken on the loom.
    2010 Škoda Fabia 1.6 TDI CR (105) Elegance (31k)
    2002 A2 1.4 TDI SE (130k)
    2001 A4 2.5 TDi Avant Quattro Sport, aka Amrak Locomotive (162k)
    1995 80 TDI Avant SE (175k) Sold
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Well, I did not have a time (mood :?) to play with the wires and today light did not come back anymore. So hopefully it's all ok now.
    I did not know that its common problem with these cars, as my FL 1.9TDI PD never had any issues with it. I'll be aware now for the next time.
    Thanks everyone.
  1. Brake pad wear sensor wiring
    By Rupert25 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th December 2013, 23:25
  2. Audi brake pad wear sensor
    By spartacus 68 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2012, 23:11
  3. Front brake pad wear sensor lead?
    By rockape in forum A3/S/RS Parts
    Last Post: 6th December 2011, 13:14
  4. Pre-facelift S3 brake pad wear sensors or not?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2011, 17:50
  5. Replies: 15
    Last Post: 27th May 2008, 20:41
