JMB RetrofitsAH Fabrications
    Dec 2013
    Huddersfield
    6
    Suspect heater matrix? Help!
    Last weekend I replaced a coolant seal on the housing at the rear of the engine (that leads off to the bulkhead with the 3 heater plugs in)... Now I didn't disturb the two pipes that join to the matrix but ever since I've had horrendous steaming up issues, coolant smell in the car and loss of coolant. I've monitored the level and I found one of the two pipes that connect to the matrix to be leaking, so tonight I've replaced the hose clips, cleaned off and topped up the coolant. My question is.. If the leaking pipe was the issue 1,how has coolant got into the matrix and 2, how long will it take to coolant to remove itself from the air box And 3 has anyone else had this problem and what are the matrix like to do??
    Thanks in advance
    jbh
    jbh's Avatar
    TDi lover
    Slamannan/ Central Scotland
    704
    not sure about the A4 but I done a heater matrix in a passat a few years back.
    I had to remove the dash which originally I was dreading but to be honest its not the worst one ive done.
    I had it stripped and built in a day
    1997 A4 Avant 110 TDi quattro
    1996 A4 Avant 110 TDi breaking
    Dec 2013
    Huddersfield
    6
    Yeah I'm dreading this too, it's my daily runner!
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,138
    Dash out job on the A4 im affraid !
    davy j's Avatar
    Jun 2013
    Edinburgh
    74
    done my own matrix
    takes longer to find all the screws than taking it out but worth doing
    Took me i day for a strip and rebuild
    if you are loking fora matrix i would recommend this one
    AUDI A4 HEATER Matrix 1996-2005 | eBay
    Bought 2 off of them and got a quick delivery
  1. Steamy windows, heater matrix, air con...
    By adbett in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2010, 09:47
  2. Heater Matrix
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2009, 18:19
  3. Golf Mk2 Heater Matrix!
    By jojo in forum Volkswagen and other VAG
    Last Post: 28th March 2007, 03:51
  4. Heater matrix - no hot air!!!
    By RickT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th February 2007, 13:45
  5. changinf heater matrix... how?!
    By imported_mattsavage in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 16:47
