Results 1 to 9 of 9
Thread: Engine problems
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    Engine problems
    Hi All, I know this isn't A3/S3 related but i know there's a lot of knowledgeable people here.
    My boss has a 2000 b5 rs4 with a few problems and need some help diagnosing whats wrong with it.
    I took it for a drive today and its got a bit of a lumpy idle doesn't really settle. when on boost its got a very slight stutter and doesn't pull so smooth.
    He recently blew the turbos and has just had two brand new one's fitted a couple weeks ago not sure if this could be anything to do with it?.
    Anyway i checked for fault codes and here is what i got:
    16730 Camshaft position sensor
    16730 Engine speed sensor
    17930 Camshaft adjustment bank 2
    18010 Power supply b+ terminal 30, voltage too low
    Any Help would be much appreciated.
    Thanks, Danny
    AMD stage 2 map, BBS LM 19s, 20mm Momo Spacers, Black Diamond Discs, Ferrodo ds2500 pads, Milltek Exhaust, Pipewerx downpipe and Decat, Custom FMIC, 4 bar Fuel Pressure Regulator, Forge 007p, Forge short shift, Forge DV relocation ,Forge TIP, S2000 Filter, Sachs Race Clutch, Sachs Light weight Single mass flywheel, ForgeOil catch tank, De baffled Charge pipe & Polished, Polished Inlet Manifold, N249 Delete, PCV Delete, Red Engine Mounts, Forge Boost hoses, Angel Eye Headlights, LCR Splitter,
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    have you tried resetting?
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    resetting? as in erasing the fault codes?
    Jan 2014
    Blackburn
    44
    Could be a timing issue with all the related sensor faults being logged. Has it had the belt done recently?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by Danny Cawsey View Post
    Yes mate, just seems like codes you would get after an overhaul of the engine
    Jul 2007
    London
    3,234
    Take rocker covers off, i am pretty sure the cams are worn...
    FOR SALE:
    Sulli79's Avatar
    Oct 2010
    Surrey/Berkshire
    495
    Think you can check the timing in one of the measuring blocks on vagcom
    1999 1.8TQS Saloon in Black/Dirt
    1999 1.8TQS Saloon in Silver Breaking
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,134
    Check timing also clean up all the earth points behind coolant bottle sure ive heard of bad connection/high resistance causing a similar issue !!
    Why did the turbos blow ?? Sounds like its pulling timing back on bank 2 maybe due to worn cams as above ??
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    The fault codes arent complete, the description bit that tells you whats actually wrong hasnt been posted.
    Theres also a duplicate Pcode with two different names, which isnt possible. (the second one)
    The first code and third code both point to mistimed engine or a broken/faulty tensioner.
    16730/P0346 - Ross-Tech Wiki
    17930/P1522 - Ross-Tech Wiki
    The last code just means the battery was disconnected at some point.
    TD5 Land Rover Defender build
  1. 2000/2001 A3 TDI (ENGINE PROBLEM)!!!
    By mr964porsche in forum Diesel forum
    Last Post: 26th June 2006, 23:32
  2. Diesel Engine problems
    By sinbadfury in forum Diesel forum
    Last Post: 16th May 2006, 15:26
  3. 2000 A6 2.8 Quattro engine problem
    By bullcell in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th August 2005, 23:02
  4. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
  5. Engine Problem - 2.6 V6 - possibly ECU Fault -
    By imported_k15hvc in forum Classic Audi Forum
    Last Post: 11th July 2004, 21:40
