Chris NottEM Tuning
Results 1 to 9 of 9
    Mar 2014
    Bournemouth, UK
    Newbie with a audi a4 B5 1999 - few issues!
    Hi all,
    I recently brought a audi a4 b5 1.8 1999 143k, its running nicely but has a few issues I am hoping you will be able to help with.
    1) Windscreen fogging up and car smelling of coolant - the blowers work well, really warm. From reading around I guess there is a small leak in the heater core. Does this have to be replaced or would something like k seal work?
    2) Lose of power on the low end of the revs - hard to explain but sometimes when I am in a gear and have slowed down so the car is basically driving on tick over but have not pressed the clutch and go to set off again, I'll put my foot down and nothing will happen for at least 1 second. There was oil on one of the spark plugs so today I cleaned them and replaced the valve cover gasket but its still doing it.
    3) Idle - when I slow down the revs do odd things, if i am rolling in neutral to a stop they will stay at 1500-2000rpm until I am stopped then they come down but hunt around a bit.
    3) Central locking. The car only came with one key that doesn't have any buttons. It has central locking but i am not sure about REMOTE central locking. I don't want to buy a key with buttons until I am sure the car has remote central locking!
    4) Coolant has a little bit of oil in it but has not turned muddy - I think there could be a leak in the oil cooler gasket....
    Cheers all
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,460
    Hi, welcome to audi-sport.net. Lots of info in the faqs thread. Im sure the guys will be along to advise you as well. Enjoy the forum. x
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,006
    Point 1is a leaking heater matrix. K seal is not recommended and if you did use it it won't work for long.
    The other fins will break down and leak in the end.
    3, yeah it will have remote central locking being that age.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Bradderz_1988's Avatar
    Aug 2010
    Westhoughton, Bolton
    3,136
    1) heater matrix
    2/3) throttle body alignment, air leak, check for codes, check pipe work, disconnect maf see if it runs any better.
    4) new remote and coding
    5) oil cooler, headgasket
    Do a compression test and pressure test then go from there
    Mar 2014
    Bournemouth, UK
    I've seen a video of a heater matrix being changed in s4 and they took the whole dash out! I can't be bothered with that lol car is so old and was so cheap its not worth imo.
    Will check for air leaks etc didn't think of that. I have a cheap obd2 code reader but it says link error during scanning. do i need something special to read codes?
    Hoping its not the head gasket, (really, really hoping) oil looks fine (other than it sometimes has bubbles in it)
    What does coding a new key involve? Ie can i do it myself?
    Aug 2010
    3,136
    You need vagtacho to code keys
    Oil on mine sometimes has bubbles in it now and again when hot
    Code reader - ebay vagcom lead and software
    Heater matrix is a dash out you could try k seal but thats just a pikey fix or you could pipe it out but thats just pikey aswel lol
    Mar 2014
    Bournemouth, UK
    I've seen a few people suggesting piping it out, I guess that would mean no hot air to the cabin though won't it? Would be ok for summer though lol
    Mar 2014
    Bournemouth, UK
    And lastly, can't believe I forgot this.... fan is always on! any ideas? relay maybe?
    Aug 2010
    3,136
    They have a viscous fan thats constantly on as is driven of the alt belt iirc and an electric fan that comes on when a/c is switched on (econ light off)
  1. Audi Newbie with a few questions
    By eddie2602 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st February 2014, 23:45
  2. Back.... With a new Audi. An A4 Cab.... few newbie questions...
    By dares_uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2014, 15:45
  3. newbie with 2011 audi a4 black edition
    By raiman in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 12th September 2012, 19:58
  4. Newbie with 03 Audi A4 :)
    By AudiAndy21 in forum The Welcome Section
    Last Post: 18th October 2011, 22:13
  5. Newbie with First Audi
    By samuelt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th May 2006, 21:12
