Badger5Monster Motorsport
Results 1 to 8 of 8
Thread: Non-Starter
    Oct 2005
    Lancashire
    Non-Starter
    Hi guys,
    I’ve had my audi (1998 2.5 TDi Quattro) for a mere 4 months now and after discovering a couple of minor problems with the car I now have a major problem which I’m hoping someone has seen before.
    Last weekend my car suddenly stalled & since then I’ve been unable to start it. I got it toad to my mates house since he knows quite a bit about cars so he could take a look. He initially thought the problem was with the fuel pump but on closer inspection he said it’s working fine but it seems the fuel is leaking back to the tank. Could there be a valve or device that is cracked causing a leak on the pressure side of the fuel line in the tank causing this circulation problem? If so is it a common audi fault?
    I’m beginning to get worried that this is going to be expensive to fix since it looks like a garage will have to strip down the unit to workout where the problem is.
    Any advice would be much appreciated - I need to get back on the road!
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: Non-Starter
    Post in Diesel section more Diesel minded there
    What were the minor faults?
    I take it you have checked the obvious things ...like water in the diesel tank .........Leaking back to the tank what do you mean?
    Sounds like fuel related problem what mileage is on the car?
    Oct 2005
    Lancashire
    Re: Non-Starter
    Rev-head,
    The 2 minor faults(minor as in I can live with them but ideally get them fixed) both occur when the car is cold.
    1. The concert stereo volume control jumps between min & max (it's fine when the cars warm!). It would be useful to know if it’s fixable or better just rip it out & fit a different stereo?
    2. I think it’s called the compressor! (star-shaped icon that appears when you press the ‘auto’ button for the heating), just won’t stay on when the cars cold but fine when warm. I would guess that this would be quite expensive to fix but it doesn’t affect the car warming up & holding the required temperature so I’m not quite sure what it actually does.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: Non-Starter
    First problem is stereo just replace it...strange how it gets better when warm bizarre????
    Second is Air Con Star shaped button would not think it would come on as it will wait for the car to heat up first and matters what temp you set car to.........As you say as long as the car heats up thats all that matters
    Steve
    Jun 2003
    Hythe, Kent
    1,180
    Re: Non-Starter
    [ QUOTE ]
    [/ QUOTE ]
    I hear that's quite normal, and it was certainly the case on mine.
    From what I read the "chip" which is at the bottom of the volume problem is easier to write data to when warm so the problem clears up.
    Kev.
    EDIT: More reading on the volume problem here.
    Oct 2004
    Southampton, England
    86
    Re: Non-Starter
    some fuel will go back into the tank on the return pipe,
    but some fuel pump can fail and just leak all the fuel they have just pumped straight back into tank.
    pull a pipe off in engine back and see if any comes out, easy
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: Non-Starter
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    Kev.
    [/ QUOTE ]
    You learn something new everyday ...........I take it is a easy job to fix?
    Jun 2003
    Hythe, Kent
    1,180
    Re: Non-Starter
    About Ł80-Ł100 I'm led to believe.
    I had my CD changer pack up and my volume control at the same time. Ł250 for a new changer from VAG Parts and Ł??? for a new stereo.
    So I got a new Sony HU and iPod interface and all connecting cables for less than Ł300.
    Kev.
