EM TuningChris Nott
Results 1 to 8 of 8
Thread: Facelift Alarm
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,016
    Facelift Alarm
    Anyone ever fitted a facelift alarm siren to a PFL to remove the crap horn?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    foursprungdugtechnique's Avatar
    Jan 2011
    Perth, Scotland PH1 2BN
    279
    The problem with the FL siren is that you'll have to buy a new one, they will all have packed up by now in scrapped cars.
    I think there's a battery inside them that leaks and corrodes them to death inside.
    I may be wrong, but I've not found a working replacement yet in a scrapper.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    You cant swap it because the old one is just a two wire horn, whereas the newer one is a electronic box with a bus interface etc.
    I thaught all cars with RCL had the later siern though?
    TD5 Land Rover Defender build
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,016
    Not mine.
    I got RCL, wee button on the B pillar and my pump receives the boot popper button.
    I understand its got electronic box and stuff to it.
    How does that fit in with the pump?
    What needs wiring in?
    I'm not worry bout the batteries.
    I can try and hunt one down.
    2,175
    It's not the battery that are the problem it's the acid that comes out of them and destroys the circuit board, there is so much damage it's not repairable.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,016
    Going by ELSA PFL alarm has 2 cables.
    B1 and ground.
    The FL has 3 cables.
    B1, 12v and ground.
    If the B1 cable sends the same signal it should be easier enough to do with just fitting a 12v feed for it.
    Apparently any ciren from a Audi will fit.
    It should make it easier in finding one that's not fubar.
    B5 BIKER's Avatar
    Jul 2011
    GALWAY, EIRE
    241
    I used one from an A8 Scott and it worked fine
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,016
    Thanks mate.
    I'll keep my eyes open for a cheapy as a trial.
  1. Problem with alarm
    By tim in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2003, 12:58
  2. CLIFFORD Car alarm (Turbo Timer thing)
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2003, 13:03
  3. Problems with alarm transmitter.
    By DJG in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2003, 08:23
  4. Clifford Smoke Alarm
    By Moresauce in forum Other Brands & Models
    Last Post: 11th January 2003, 12:54
  5. A3 Alarm
    By markp in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2003, 15:11
