EM TuningAH Fabrications
    Aug 2005
    West Sussex
    45
    Dashboard computer and veggie oil
    I've had this dashboard computer glitch on my 98 A4 TDi for months. The brake light bulb out warning light comes on and the dreadful chime intermittently, probably 3 or 4 times on a 50 mile journey. Yet no bulb is out and the brake light switch has been replaced. Any Audi specialist cooected it to their computer and said they couldn't find anything wrong so it must need a new computer, but I baulk at paying out 500 for that and was wondering if anyone could give me a second opinion. Also is it true what I read in the paer the other day, that modern diesels will work quite happily on an equal mix of derv and vegetable oil?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Re: Dashboard computer and veggie oil
    Ok, are you sure its the bulb light and not a brake fluid warning or pads warning?
    To if not that check and replace all the bulbs, as this would be a cheap option it could even be the third brake light thats out. Also check and see if anyone has tamped with the wiring and this would also show a fault.
    If it is the clocks (which I would not have thought so) you could by a second-hand unit and have one of those dodgy clocking company recalibrate the mileage.
    tubtub's Avatar
    Jul 2005
    SW England
    160
    In answer to your second question: linky
    Aug 2005
    West Sussex
    45
    Many thanks.
