AH FabricationsVolks Autos
Thread: Pedal play
    Apr 2011
    79
    Pedal play
    Hi everyone....has anyone any experience in having excessive play in the brake and clutch pedals? Cars a 99 A4 QTS - It's side to side movement. I looked up in there And it reminds me of a push bike crank bearing layout....I've tightened the nut but it hadn't worked it's way loose to be fair and and changed nothing. These expensive to replace? Hard job? Cheers
    matt66604's Avatar
    Dec 2013
    Aberdeen
    52
    You're gonna have to find which bushes are worn on your respective pedals.
    I noticed when I braked I could feel the movement from the brake pedal ever so slightly in my clutch pedal
    Went into the parts department at work and looked through etka.. They're all listed seperately
    Easier to just order all the bushings tbh... Not too expensive.. Or 2nd hand pedal set
  1. Audi A3 2004 Clutch pedal play.
    By sprint3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2010, 20:30
  2. golf GTI 2.0 8V, playing up, need help!
    By Dr_Lokos in forum General Technical / How To
    Last Post: 26th August 2003, 18:11
  3. TT pedal set part numbers
    By ooooaudi in forum TT/TT-S/TT-RS Forum
    Last Post: 9th April 2003, 20:20
  4. tt pedal set part numbers
    By ooooaudi in forum General Technical / How To
    Last Post: 9th April 2003, 20:16
